01-23-2014, 08:31 PM | #1 |
Newbie Join Date: Nov 2013 Location: Los Angeles
| recommend me an aluminum steering servo horn
the plastic one is kinda shot how many teeth is the stockhorn? thanks |
01-23-2014, 08:39 PM | #2 |
Quarry Creeper Join Date: Nov 2012 Location: spanish fork
25 tooth I believe any are better than plastic Sent from my VS980 4G using Tapatalk |
01-24-2014, 08:54 AM | #3 |
Rock Crawler Join Date: May 2013 Location: Rancho Cucamonga
| Re: recommend me an aluminum steering servo horn
Good luck getting the stock gear off of the servo. Mine wouldn't budge, so I just replaced the whole thing with a Solar D772 and a Racers Edge arm.
01-25-2014, 03:32 PM | #4 |
no i have an upgraded servo. i guess my terminiology is wrong. the horn is the part on the servo right?? because mines is metal but i need the part that connects the horn to the linkage. idk what its called |
01-26-2014, 10:37 PM | #5 |
if you have an upgraded servo, then you're good to go. Get a Racers Edge horn. They're a bit longer and allow more leverage on the steering if you use the end hole (has 2 holes). I think RPP has them.
01-27-2014, 06:12 PM | #6 |
this is the part i need Amazon.com : Servo Horn, 25T, Aluminum: 22 : Hobby Rc Vehicle Servo Horns : Toys & Games my stock one is stripped. will this fit on the hammer? i mean if it will not hit the shocks at full throw |
01-28-2014, 08:57 AM | #7 |
Depends on how much that offset is on the arm's bend. You may have to limit your epa.
recommend me an aluminum steering servo horn - Similar Threads | ||||
aluminum servo horn | 92civic | Electronics | 7 | 07-27-2009 12:20 PM |
Aluminum servo horn | gotmax59 | Electronics | 4 | 05-15-2007 09:52 PM |
