04-21-2014, 03:57 PM | #1 |
Rock Crawler Join Date: Mar 2014 Location: Dallas, Texas
| GCM Front Mount with 85mm Gmade shocks - Springs?
So I have the GCM front mount and the 85 mm aeration shocks. I do not have the batter up front, but I will include a very small 3S pack in a few days for the lights I will install. The point is not a lot of weight in the front. What springs is everyone running with a similar set up? I am using the stock gmade oil with the 2 hole pistons. I think I am set up correctly for some low altitude jumps, I don' think I am set up well for general bombing around. I am able to see proper articulation under acceleration, braking and leaning while turning. However, it seems a little stiff over bumpy terrain. I also can't seem to get the suspension to work properly at higher speeds. For example, I get a forward flip if I hit a small bump in the sidewalk where my much smaller mini 8ight will take it like a champ. Possibly a kick up angle issue?? Any help would be appreciated. I am running closed foam inserts with Interco IROC tires on Bombshell rims (it looks awesome). |
04-22-2014, 05:31 PM | #2 |
| Re: GCM Front Mount with 85mm Gmade shocks - Springs?
How does this have 80 views an no comment? I am shocked!
04-23-2014, 01:15 PM | #3 |
Quarry Creeper Join Date: Dec 2012 Location: SoCal
| Re: GCM Front Mount with 85mm Gmade shocks - Springs? I'm gonna guess the reason is because there are so many variables involved, it's kinda pointless. I'd start with the springs that come with the G-Mades and juggle springs and shock oil until you are satisfied. It's not that expensive and when you change something you will have resources ready for adjustments |
04-24-2014, 09:26 AM | #4 | |
| Re: GCM Front Mount with 85mm Gmade shocks - Springs? Quote:
Perhaps URC will have some people who can share their set ups and report on the performance. | |
04-24-2014, 09:33 AM | #5 | |
04-24-2014, 10:26 AM | #6 |
Pebble Pounder Join Date: Oct 2011 Location: Wichita
I'm pretty sure GCM doesn't recommend using shocks longer than 80mm. Sent from my XT1056 using Tapatalk |
04-24-2014, 01:04 PM | #7 |
| Re: GCM Front Mount with 85mm Gmade shocks - Springs? |
04-24-2014, 01:32 PM | #8 |
Quarry Creeper Join Date: Jun 2011 Location: panama city
I like 80 wt oil in mine to soak up the bounce. that way the springs dont Spring back so easily
04-24-2014, 03:11 PM | #9 |
Rock Crawler Join Date: May 2013 Location: Rancho Cucamonga
Lightest spring as you can find and have it still support the rig. Keeps the suspension active. There are a few trains of thought on the oil/piston issue. Thin oil, lots of holes vs. thicker oil and fewer large holes.
04-24-2014, 03:18 PM | #10 | |
As for limiting travel, I used 6mm of fuel tubing to give me the limitation I needed. I do wish I had more upward travel, but the rig already loves to float around. I am also thinking when I rig my lights and put a small 3S battery in the front it will help some of the issues I am encountering. | |
GCM Front Mount with 85mm Gmade shocks - Springs? - Similar Threads | ||||
GCM Racing Front Shock Mount!! | djmaincheese | Vaterra Twin Hammers | 13 | 11-29-2016 07:09 AM |
GCM Axial trans Front Mount | Generis | Axles, Trannys, T-case | 8 | 12-06-2012 09:20 AM |
