05-02-2014, 11:07 PM | #1 |
Rock Stacker Join Date: Dec 2012 Location: chandler
| Twin Hammers Rear Gear Ratio
Ok so I have my Twin hammers for a year now and it has been a money pit for me. I have changed just about every thing I could to make this buggy fast and durable. Now I have broke the rear diff gears or something like that in the rear axle housing. So My question is has any body tried to put an Axial rear locker and gear set in the housing of the twin hammers? Or maybe some knows the ratio of the gears and I will just swap the rear axle out with something fro Vanquish or RC4WD. Thanks for the help David |
05-05-2014, 08:26 AM | #2 | |
Rock Crawler Join Date: Mar 2014 Location: Dallas, Texas
| Re: Twin Hammers Rear Gear Ratio Quote:
As for speed, go brushless, get a motor above 3500 KV, and some say at or below 4600 KV, and try to go with a 4 pole. The gear accordingly, and be sure to put on rear sway bars. You can order a 4 pole 4350 KV motor that will work perfectly for like 30 bucks. I know because I have one just sitting around, maybe I will install it at some point. If you are already running brushless, turn the punch down as it really doesn't help anything with this vehicle except to break stuff. My TH gets run about 8 times a week, as it is in various states of disassembly, although I think I am in the home stretch and hope to install the remaining lights tonight and button everything up. You can also get steel gear sets for the transmission. The most obvious answer would be to take it easier on the throttle and loosen the slipper a touch. I hope some of that helps! PS I am running the Castle 3800 KV with a 26t pinion and 78t spur on 3S. Other than drive nuts crapping out, I have had no problems at all... | |
Twin Hammers Rear Gear Ratio - Similar Threads | ||||
exo with solid rear or twin hammers? | smokinloon | South Carolina | 1 | 01-08-2014 05:18 AM |
Vaterra Twin Hammers 78T Spur Gear | eggymusstaka | Vaterra Twin Hammers | 17 | 04-06-2013 07:35 PM |
Gear Head RC Twin Hammers Shift Servo Plate | Gear Head RC | Chassis and Suspension | 3 | 02-25-2013 03:14 PM |
Gear Head Twin Hammers Standard Servo Shift Mount | RPP Hobby | RPP Hobby | 0 | 02-20-2013 06:41 PM |
