03-18-2013, 01:59 AM | #1 |
Newbie Join Date: Mar 2013 Location: Tasmania
| Vaterra Twin Hammers 78T Spur Gear
I am curious to know if there is a Losi spur gear that meets the same specs as the Vaterra Twin Hammers 78T Spur Gear. Noticing most shops have back order or little stock. I also found that there is 3 entry points for rocks and other bits around the motor housing bracket (green aliminium). Would highly recommend blocking them off to prevent rocks eg getting in there. Seeing as this has been my only problem with my Hammer since going hard with it. |
03-18-2013, 02:29 AM | #2 |
Newbie Join Date: Mar 2013 Location: M-ville
| Re: Vaterra Twin Hammers 78T Spur Gear
Anything for the TLR 22 series truck will work with the T.H. Also if your wanna run 32p you can get a spur gear from losi xxx-nt |
03-18-2013, 08:29 AM | #3 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
| Re: Vaterra Twin Hammers 78T Spur Gear |
03-18-2013, 09:44 AM | #4 |
Pebble Pounder Join Date: Jan 2013 Location: San Diego
I've been using a 51t 32p losi Kevlar spur. Works great and fits the clutch perfectly. I chewed up a couple teeth this weekend when done dirt got in...I suspect it was in the spot you described. I think the dust cover design is kinda lame. It only has two screws on top, but you still have to take the tranny out to remove it. They should have put a screw or two on the bottom at that rate. |
03-18-2013, 11:43 AM | #5 | |
| Re: Vaterra Twin Hammers 78T Spur Gear Quote:
No you dont... just pop the rubber piece off, unscrew the screws and slide it out. All that gets hung up is the removeable rubber cap. | |
03-18-2013, 02:34 PM | #6 |
Pebble Pounder Join Date: Sep 2011 Location: Oceanside Ca
If dirt gets trapped in there way run a cover at all?
03-18-2013, 05:44 PM | #7 |
Cheers Soulo and Sethmetal.
03-21-2013, 06:58 PM | #8 |
Newbie Join Date: Feb 2013 Location: Louisville
Part #: TLR3980 Exact replacement but in Kevlar!
03-21-2013, 07:05 PM | #9 |
Pebble Pounder Join Date: Feb 2013 Location: Ramsey
If you want i have 3 brand new kevlar spurs still in pack (2- 70t and 1- 76t) and one used 78t ( 2 packs through it.) I dont need them as i switched to 32p. pm if interested
03-23-2013, 11:24 PM | #10 |
Ty Tbuck
04-01-2013, 10:46 PM | #11 |
Quarry Creeper Join Date: Dec 2012 Location: Canada
Add me to the bad spur gear list Mine was likely because if sand The cover doesn't do jack all Need to mod that somehow to keep shit out |
04-02-2013, 07:46 PM | #12 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| Re: Vaterra Twin Hammers 78T Spur Gear Im runing 18 on the pinion and 87on the spur |
04-05-2013, 02:43 PM | #13 |
Is the losi a direct swap in?
04-05-2013, 05:26 PM | #14 |
04-05-2013, 06:14 PM | #15 |
| Re: Vaterra Twin Hammers 78T Spur Gear TLR 78T 48P Kevlar Spur Gear TLR3980, Losi 22 B is a direct fit razor. And I just cut up a coke can to make a cover for the entry points around the motor to save my spur gear. Working well so far |
04-05-2013, 08:58 PM | #16 |
Thanks gents I have some on order Pop can is a good Idea. |
04-06-2013, 03:38 PM | #17 |
I also bought a 76t losi spur today that should fit Same pitch I can't wait for my order to arrive in 2 weeks; I wanna driver now Damn it lol |
04-06-2013, 07:35 PM | #18 |
Quarry Creeper Join Date: Jul 2011 Location: Hemet
im runnin 30 pinion, and a 90 spur..... working great so far with my 35 turn integy motor, the spur is off of a sc10 I beleive
Vaterra Twin Hammers 78T Spur Gear - Similar Threads | ||||
Vaterra twin hammers has ARRIVED | CRAWLER-DAD | Arizona | 29 | 03-07-2013 12:50 PM |
Jami's Vaterra Twin Hammers | jami_p | Vaterra Twin Hammers | 29 | 02-26-2013 06:19 PM |
Vaterra Twin Hammers In Stock | RPP Hobby | RPP Hobby | 4 | 02-13-2013 02:55 PM |
