Originally Posted by Sr.Irie Have a feeling if you measure from center to center off both links they are the same or very close and could be exactly the same if adjusted. I believe the turnbuckles not being the same from the left side to the right side is what you are seeing. If you look at the right side the threads go almost up to the adjuster flats. Then on the left they are much further away from the adjuster flats. |
Now that you say that and I look closer, I realize exactly what you are talking about because the two links are different. I can't believe that I didn't even notice that when I was adjusting them. I would have definitely noticed it had I been the one who assembled them but oh well. I guess the guy that assembled it had the links out of whack to begin with but I didn't pull them apart to check them because everything was straight when I got it. I am thinking that maybe the link to the rack wasn't adjusted properly and he had adjusted the links to the knuckles in order to correct it. I may just go ahead and replace them because they are soft and starting to round off anyways so I can make sure that I have some good Traxxas links that are the same length.
