03-18-2015, 04:24 PM | #1 |
Pebble Pounder Join Date: Apr 2011 Location: State Road N.C.
| Chattering front end
When I run a locker in my front end I get a lot of chattering when the steering is a at full left/right. It doesn't do this when the locker is removed and is filled with diff fluid. Any ideas?? |
03-18-2015, 05:30 PM | #2 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
| Re: Chattering front end
With the fluid filled diff the outside tire in the turn can spin faster than the inside tire when you turn. By locking the front end you are causing both wheels to spin at the same speed and that will make it jump at full lock steering. |
03-19-2015, 01:56 PM | #3 |
Is this because of the use of CVD's on an independent front end? I never noticed this on my SCX-10. Is there a fix for this? |
03-19-2015, 03:27 PM | #4 | |
| Re: Chattering front end Quote:
The only cure is an open diff which is no fun to me if you're crawling and the only time I notice is testing in my shop. Running loose surfaces like dirt you really shouldn't notice it too much. | |
03-21-2015, 06:24 AM | #5 |
Quarry Creeper Join Date: Dec 2012 Location: SoCal
Believe it or not, it's normal for the TH. The CVDs have only very limited angular range and when you approach the limit, It sounds and feels like the thing is coming apart. Adjusting the steering lock will help keep it in the sweet spot but it also reduces the turn radius obviously. The locker makes it more obvious but they all will do it near full steering lock. It's just one of the pleasant gifts Vaterra gave us on the front end of the TH. A real bummer.
Chattering front end - Similar Threads | ||||
Front chattering! | biomanz | Axial SCX-10 | 7 | 05-01-2013 07:06 AM |
front end | flexedout | General Crawlers | 4 | 06-28-2006 10:14 PM |
front end | norcaljeep | General Crawlers | 2 | 05-19-2006 03:54 PM |
