02-05-2016, 09:56 AM | #1 |
Pebble Pounder Join Date: Dec 2014 Location: NJ
| How to remove rear shock?
Noob question: How do I remove the rear shock from its lower mounting position? I have removed the screw that goes thru but the shock won't budge. |
02-05-2016, 10:01 AM | #2 |
Pebble Pounder Join Date: Nov 2015 Location: Bay Area
| Re: How to remove rear shock?
Probably need to pull harder? Seriously. Sent from my XT1096 using Tapatalk |
02-05-2016, 10:03 AM | #3 |
Newbie Join Date: Nov 2013 Location: Sweden
All you need is the right amount of force. Use a flat screwdriver and bend carefully upwards. Skickas från min iPhone via Tapatalk |
02-05-2016, 10:11 AM | #4 |
Rock Stacker Join Date: Sep 2013 Location: San Diego
Come on junior...use some muscle...like Ronken said, use a small flat head and pry that bitch out.
02-05-2016, 10:19 AM | #5 |
Thanks. I thought that it should just pop right out but wanted to be sure. Will try again with more force when I get back from work.
02-05-2016, 10:21 AM | #6 |
Just doing some service on the shocks or ?
02-05-2016, 11:07 AM | #7 |
| Re: How to remove rear shock? |
02-05-2016, 11:51 AM | #8 |
Smart move my friend, just did a full rebuild/check on my rear shocks the other week.
02-05-2016, 06:21 PM | #9 |
So did they finally come out? Sent from my XT1096 using Tapatalk |
02-05-2016, 08:00 PM | #10 |
02-05-2016, 08:54 PM | #11 |
Rock Crawler Join Date: Jul 2005 Location: Playing with toys with my son's
Tools needed: A good strong string Step ladder Broom stick Naked pictures of Bea Arthur Flat tip screw driver Acme anvil Trailing arm/stuck shock Instructions: Set up the step ladder, position the anvil atop the broom stick and atop the ladder. Then tie the string to the broom stick. Stand back and give the string a good tug. If positioned right the anvil should fall. Now mark the spot on the floor, if the anvil has not done it for you. Now set the anvil back atop the broom stick atop the ladder as you did before. Now position the trailing arm with the stuck shock on your mark with the flat tip driver in the pocket of the trailing arm, under the shock end. Back up pull the string and Whaaa Laa |
How to remove rear shock? - Similar Threads | ||||
Easier way to remove rear body pins on Honcho? | jeff22 | Axial SCX-10 | 16 | 02-02-2015 03:12 PM |
how to remove the rear axle? | dirtslow | Axial Wraith | 2 | 09-26-2012 07:31 AM |
Rear Shock Mounts? | Grumpster1980 | Tamiya XC/CC01 | 26 | 02-19-2010 11:25 PM |
word to the wise remove spring before changing shock oil | slobin3d | Chit Chat | 1 | 10-12-2006 10:38 PM |
