04-24-2016, 03:06 PM | #1 |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
| Twin Hammers Rubber boots
With all the abuse at the beach, i've been finding the drive shafts are getting a hard time. Who'd of thought sand and salt water were bad for moving parts? I've just fitted some rubber boots, as below. I've used vaterra glamis boots on the mid shaft and inner drives, and cut down Tamiya boots from rc channel on the outdrives. The caster blocks needed a bit of fettling to give a bit of clearance, as did the gearbox front support. I have my doubts at to how long these will last before getting torn up..... |
04-24-2016, 03:55 PM | #2 |
Quarry Creeper Join Date: Feb 2016 Location: Australia
| Re: Twin Hammers Rubber boots
Sweet. I plan on using at the beach so keen to see how this goes :-) Sent from my SM-N910G using Tapatalk |
04-26-2016, 01:54 PM | #3 |
Part number of these booties?
04-26-2016, 02:12 PM | #4 |
| Re: Twin Hammers Rubber boots |
04-26-2016, 02:14 PM | #5 |
As you can maybe see in the pictures, the sway bar also requred a bit of a tweak to get it clear of the inner boots.
08-26-2016, 02:19 PM | #6 |
| Re: Twin Hammers Rubber boots To close this one off.... After a fair bit of use, as you can see, the cvd boots died. The glamis outdrive boots on outdrives and transfer shaft faired ok. One got damaged by a trapoed stone, and the transmission end trasfer shaft boot eventually sheared due to the sharp edge of the outdrive. They did a good job of keeping out a lot of sand though. The transfer shaft boots will stay, but i've not bothered replacing the others. |
08-26-2016, 03:03 PM | #7 |
Pebble Pounder Join Date: Jul 2013 Location: El Centro
Maybe some shrink wrap can be a cheap an easy way of replacing those high wear areas. -Corrupt |
Twin Hammers Rubber boots - Similar Threads | ||||
Twin Hammers cage on SCX chassis bouncer conversion aka Bounce Hammers! | mce076 | 1.9 Scale Rigs | 36 | 07-25-2015 02:16 AM |
My Twin...Twin Hammers build start | sanny632 | Vaterra Twin Hammers | 8 | 03-09-2014 12:01 PM |
Savage00's Twinny Twin Twin Hammers | Savage00 | Vaterra Twin Hammers | 16 | 09-19-2013 08:09 PM |
Twin Hammers in Twin Cities? | 89XJ | Minnesota | 7 | 05-06-2013 02:59 PM |
Boots shift boots shock boots | toy4crawlin | Scale Accessories | 4 | 06-16-2009 02:40 PM |
