06-02-2016, 08:32 PM | #1 |
Rock Stacker Join Date: Sep 2015 Location: Oklahoma City
| Just ordered my kit...need advice
I'm looking more towards speed (brushless)...with a Lil bit of crawl action.....what do you guys recommend for a servo and motor/esc? Sent from my SAMSUNG-SM-G935A using Tapatalk |
06-02-2016, 08:54 PM | #2 | |
Quarry Creeper Join Date: Feb 2016 Location: Australia
| Re: Just ordered my kit...need advice Quote:
A rear sway bar is a must for speed. Sent from my SM-N910G using Tapatalk | |
06-02-2016, 09:04 PM | #3 |
Who makes a good sway bar? Sent from my SAMSUNG-SM-G935A using Tapatalk |
06-02-2016, 09:43 PM | #4 |
Just buy the official one. Should only be around $10 Sent from my SM-N910G using Tapatalk |
06-02-2016, 09:47 PM | #5 |
Sweet...I'll do that....would a Castle Creations combo be an alright setup for a TH?
06-02-2016, 10:36 PM | #6 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
If you want to crawl, just be sure your brushless system is sensored.
06-02-2016, 11:19 PM | #7 |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
| Re: Just ordered my kit...need advice |
06-02-2016, 11:28 PM | #8 |
06-03-2016, 01:07 AM | #9 |
Quarry Creeper Join Date: Sep 2010 Location: appleton
After going through multiple Savox 0231's I have been using a Savox 1210. Much more torque and all steel gears. Sent from my LG-H900 using Tapatalk |
06-04-2016, 06:39 PM | #10 |
Rock Stacker Join Date: Feb 2010 Location: Fitzroy Harbour, Ontario
Just a couple ideas if you're going the mostly go fast route. The GCM rear axle truss or similar solution would probable help keep the front end down under power. SrIrie is selling drilled rear axle shafts to open the rear diff, ( Got modded open diff with a front diff rebuild kit, VTR232019) combined with 500K or 1M weight diff oil, front and rear, might be a good way to do both the go fast thing and the go slow crawling thing. Or a reasonable facsimile there of. |
06-05-2016, 09:49 AM | #11 |
Thanks for the advice guys...now what about a pinion gear?...I'm sorta new to this, so I have no clue how to pick one out.
06-05-2016, 05:02 PM | #12 |
Newbie Join Date: May 2011 Location: Buffalo
I just picked up the 4600 sidewinder combo
06-06-2016, 11:25 AM | #13 |
06-06-2016, 06:02 PM | #14 |
Rock Stacker Join Date: May 2015 Location: North Lakes, QLD
Easiest fix if you want to go fast with minimal consequence is to use smaller tyres/open up the diff. Otherwise it is likely you'll be barrel rolling everywhere. Obviously this reduces top end significantly but the gearing is such that you could run a much lower turn motor to compensate. The largest pinion I could find and purchase is a 35t, you can't use the spur cover though as it wont fit. I have run a 5200 kv motor (2s only) with the 35t pinion and some slightly smaller tyres - 96mm. was way too fast for anything but speed runs imo (I aint no pro driver) but it was hilarious. (I say way too fast because I have a small area, it was only around 50-60km/h). Last edited by Chicken Man; 06-06-2016 at 06:15 PM. |
06-06-2016, 09:47 PM | #15 |
So I'm new to this build and customizing thing.....how do you open the diff? Sent from my SAMSUNG-SM-G935A using Tapatalk |
Just ordered my kit...need advice - Similar Threads | ||||
Just ordered Spawn kit, questions/advice needes | Smonkman | Axial Wraith | 26 | 07-18-2016 01:02 PM |
Ordered the Fastback II chassis. Any advice for the links ? | Pygmy | Axial AX-10 Scorpion | 11 | 01-12-2015 07:19 PM |
Kit Ordered, Parts Ordered, Suggestions??? | OkinawaCrawler | Tamiya XC/CC01 | 6 | 02-21-2014 09:52 AM |
Just Ordered My Kit... | BoardN88 | Axial XR10 | 2 | 03-31-2012 08:48 AM |
Just ordered the Enroute/Berg Tracer...need advice. | vti-chris | General Crawlers | 1 | 12-31-2009 12:00 PM |
