10-18-2016, 11:26 AM | #1 |
Newbie Join Date: Sep 2016 Location: Australia
| Motor upgrade
Hi all, I'm thinking about changing out the motor in my RTR v2 & was wondering if this will fit straight in or will I need to change other things to make it work? TrackStar 10.5T Stock Spec Sensored Brushless Motor V2 (ROAR approved) (AU Warehouse) |
10-18-2016, 06:19 PM | #2 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: Motor upgrade
Does the v2 have a brushless sensored cappable esc? The first version didn't. I have that motor in one of my TH currently, and it is just perfect for me. I have a Tekin RS esc though I think you are gonna need to get an esc to go with it. I would make sure your trans has metal gears too if you are gonna crank it up Last edited by smog; 10-18-2016 at 06:26 PM. |
10-18-2016, 08:36 PM | #3 |
| Re: Motor upgrade
Thanks for the reply. I think the gears are metal except for the spur. Might have to change it.
10-18-2016, 08:46 PM | #4 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
| Re: Motor upgrade |
10-19-2016, 03:00 AM | #5 |
| Re: Motor upgrade
Just checked the ESC & it will go down to 8t. The turnigy motor is brushless but the standard dynamite 15t is brushed. Does that matter?
10-19-2016, 07:44 AM | #6 |
Quarry Creeper Join Date: Apr 2011 Location: Germany
| Re: Motor upgrade
Hi Bart, seems your stock esc can`t handle brushless motors. You have to get a brushless esc, too. Make sure the esc is sensored and the drag brake can be set at 100%. If you go for a trackstar esc, check if the sensor cable is included. You also may want a programming card to fine tune your esc. Greetz, Stollenritter |
10-19-2016, 08:07 AM | #7 | |
| Re: Motor upgrade Quote:
The Turnigy you are looking at is brushless AND sensored. If you are not wanting to pick up a new ESC you will need to stick to brushed motors. If you do pick up a new ESC be sure it is capable of running sensored motors. Last edited by smog; 10-19-2016 at 09:02 AM. | |
10-19-2016, 08:43 AM | #8 |
| Re: Motor upgrade
Thanks heaps guys
10-19-2016, 09:44 AM | #9 |
| Re: Motor upgrade
Ok what about this combo? Turnigy TrackStar Waterproof 1/10 Brushless Power System 4000KV/80A (AU Warehouse) & why does it have so much more power when it's only a 16T? |
10-19-2016, 06:11 PM | #10 |
| Re: Motor upgrade
Anybody?
10-20-2016, 06:16 AM | #11 | |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
10-20-2016, 06:39 AM | #12 |
| Re: Motor upgrade
Thanks mate. So 4 pole is better?
11-06-2016, 11:58 PM | #13 |
Newbie Join Date: Jul 2016 Location: Lake stevens
| Re: Motor upgrade
You will want to go with a sensored brushless motor if you plan on doing any crawling, non sensored motors will cog to much.
11-19-2016, 05:16 PM | #14 |
| Re: Motor upgrade
So I ended up going sensored brushless as suggested. I got the Hobbyking xcar 120A esc/4500kva motor. In the box are 2 black caps on a board, these have a small red & a black wire coming from them. The manual doesn't mention them at all in the wiring setup & im wondering where the go?
12-04-2016, 11:42 PM | #15 |
| Re: Motor upgrade
What Pinion Spur would you guys recommend for thgis setup? I'm thinking spur around 86-90 & pinion between 20-24? I like to crawl a bit but also like the punch & speed of the 4500kv motor. Any advise will be greatly appreciated.
12-05-2016, 06:51 PM | #16 |
| Re: Motor upgrade
Anyone?
12-05-2016, 11:33 PM | #17 |
| Re: Motor upgrade
I was running 22/78 with a 4500kv puller pro. It's as fast as i'd ever want in 2nd gear, and crawls well in first. I've dropped a 32dp gear setup now.... i cant remember which sizes, but its a close equivelent.
12-06-2016, 06:21 AM | #18 |
| Re: Motor upgrade
Thanx dbx
Motor upgrade - Similar Threads | ||||
Reasons for smoking a motor? Maybe HH can help and I'll upgrade to their motor! | d-fly | Electronics | 17 | 01-26-2016 01:11 PM |
Motor Upgrade Help | mbztech88 | Axial Yeti | 0 | 12-29-2015 10:00 PM |
motor upgrade | Ohioskills | Losi Mini-Rock Crawler | 3 | 11-26-2012 06:01 AM |
Motor upgrade | Pappy | Electronics | 5 | 10-17-2010 03:31 PM |
Motor upgrade | gmcdad | Newbie General | 2 | 09-28-2010 12:11 PM |
