11-21-2016, 06:24 PM | #1 |
Rock Crawler Join Date: Feb 2015 Location: Melbourne
| Joe's TH's with BMRC and Traxxas bellcrank
I picked up a stock RTR THs from a mate cheap and it also came with a Blue Monkey RC (BMRC) front shock tower plate new in a packet. I did some research and found it can be used with traxxas slash bellcrank steering but had no luck finding any actual instructions on how to do it. So I took photos along the way. Stock form when I got it. Since it was coming apart to do the steering I replaced the plastic gears with steel ones. This is the BMRC plate with the traxxas bellcrank bolted on. There are 2 mounting pins that came with the plate. Optional purchase from BMRC. The bellcrank must be the alloy upgrade version as the arms all need moving around. Bolted on but the arm that connects to the servo was wrong and needed to be removed and adjusted until it moved in both directions without hitting anything. Final position was this. The arms on the bell crank system are pressed onto the 2 hex posts and can be removed and placed back on. They can also be moved up or down on the hex posts. You need to slide the main arms up as far as they will go without anything hitting the BMRC plate. As per this pic. Ensure it still swings in both directions without hitting anything. The other arm needs to be adjusted as high as it can go also but leaving enough room to swing under the plate. I used the factory drag link that was used on the old setup. I fitted a Hitec servo and cut down a clamping servo horn. I also put a slight bend in the drag link and trimmed the edge of the plate a little as it was rubbing. If I had a shorter servo horn it wouldn't have been required. View from the other side. Please note some of the pics taken where befote I got the lower arm set at the right angle. Make sure you set that correctly according to the 2nd pic not the following ones. Sent from my SM-G930F using Tapatalk Last edited by honchojoe; 11-21-2016 at 06:41 PM. |
11-21-2016, 06:30 PM | #2 |
| Re: Joe's TH's with BMRC and Traxxas bellcrank
I then fitted some gmade 85mm shocks. However those shocks need to come apart again and limited a little as the drive shafts are popping out in certain scenarios. Common issue with vertical shocks on a THs. Sent from my SM-G930F using Tapatalk |
11-21-2016, 06:36 PM | #3 |
As the BMRC front plate also accommodates a front mounted battery I converted it to flip front. If you look at the frame on the front you can see the point where I cut. It just fits a 2200mah 3S. Then I removed the screws on the side and and am currently using a pair of large body clips in place of the screws when closed. Sent from my SM-G930F using Tapatalk Last edited by honchojoe; 11-21-2016 at 06:38 PM. |
11-21-2016, 06:37 PM | #4 |
Not sure why the pics are sideways. I'll try to work out how to fix that. Sent from my SM-G930F using Tapatalk |
12-20-2016, 04:59 AM | #5 |
So far it has been running well other than the dog bones popping out. I'll need to pull the gmade shocks apart and fit an oring inside to limit the travel. Or somehow raise the mounting point on the BMRC plate a few mm. Also I've found the lipo cut off is not working on the original esc which is very odd. Sent from my SM-G930F using Tapatalk |
12-20-2016, 10:25 PM | #6 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
I bought my Twin Hammers used and it came with the same setup. I had trouble getting that system to work correctly. The RED drag link on the Traxxas Aluminum steering, I think is too long. When you press down on the suspension, the wheels toe outward quite a bit and caused me odd steering when driving. It was a few years back when I did this and maybe yours if fine or maybe different. But maybe check the steering when you cycle the suspension. Wheels should stay straight.
12-21-2016, 04:31 AM | #7 |
It does do that. And most bellcrank steering setups will do this if turning and deflecting the suspension. It's something I want to eventually address but not to worried about it at this point. Sent from my SM-G930F using Tapatalk |
12-21-2016, 04:33 AM | #8 |
The reason it bump steers is due to the pivot point on the bellcrank is in a different location to the suspension arm pivot so the steering knuckle is either pushed or pulled. To get rid of this you need to modify the bellcrank somehow so the rod end mount is perfectly in line with the swing arm pivot point. Sent from my SM-G930F using Tapatalk |
12-21-2016, 03:33 PM | #9 |
What I did to fix it was replace the steering with IRIE's Bellcrank setup. I also changed to the GCM Plate. No more problems. Steering works awesome. Plus I haven't had any dog bone issues popping out.
12-21-2016, 07:16 PM | #10 | |
Rock Stacker Join Date: Jun 2013 Location: Riverview
| Re: Joe's TH's with BMRC and Traxxas bellcrank Quote:
Sent from my SAMSUNG-SM-G870A using Tapatalk | |
12-21-2016, 07:27 PM | #11 |
I use a 2200mah 3s pack that I put in the rear.
12-21-2016, 07:34 PM | #12 |
| Re: Joe's TH's with BMRC and Traxxas bellcrank |
12-21-2016, 07:47 PM | #13 |
Yes I agree. I would too. But I haven't really looked that much for a 3s pack. I bought a shorty pack hard case before, but it was too too tight.
12-22-2016, 03:05 AM | #14 | |
12-22-2016, 04:30 AM | #15 |
I used the BMRC plate because it was given to me with the THs. Also the GCM plate is 4x the price. The Irie bellcrank is great and if I had the GCM unit I would be running it. As for the battery I run a Zippy 3S 2200mah lipo in the front. It just fits. But it's very tight. Slightly shorter would be better. Sent from my SM-G930F using Tapatalk |
12-22-2016, 02:29 PM | #16 | |
Joe's TH's with BMRC and Traxxas bellcrank - Similar Threads | ||||
Question about TH's two-speed transmission | drabina | Vaterra Twin Hammers | 12 | 01-08-2016 06:33 AM |
Bought 2 RTR TH's - both have issues. Need advice please | apextrans | Vaterra Twin Hammers | 2 | 12-29-2014 08:14 PM |
derwood designs vs traxxas bellcrank? | jebster | Vaterra Twin Hammers | 24 | 10-04-2013 09:47 AM |
steering bellcrank? | demonoid369 | General Scale Talk | 1 | 05-16-2011 10:21 AM |
