01-31-2017, 10:47 PM | #1 |
Newbie Join Date: Jan 2017 Location: northern california
| rear suspension links question?
so i just recently bought a twin hammers and im in the process of building it to my liking, ive gotten a gcm front plate and rear truss. still waiting on shipment but i wanted to get some more parts together while i wait. so im focusing on the rear links, uppers for now. id like to make some links from axial tubes or something similar. has anyone done this? my question is what length links and size ball ends did you use? part numbers if possible? thanks in advance!
02-02-2017, 09:46 AM | #2 |
Rock Crawler Join Date: Jul 2005 Location: Playing with toys with my son's
| Re: rear suspension links question?
Many have done this as well as myself with all sorts of different rods and rod ends. I always use the Hammer rod ends just so all the ends on the rig are the same, makes carrying spares easier. As for length start with the same length as the factory ones and just experiment, pinion angle can change torque twist.
03-31-2017, 03:50 AM | #3 |
Newbie Join Date: May 2015 Location: Siberia
Hi guys, maybe i am slowpoke, but i noticed something. If we look at yeti or rock rey rear lower links, they are | |, but TH lower links are like \ / Also if we look at 1:1 rock buggy or trophy truck, their rear lower links are almost parallel. Maybe it is a reason why TH's rear suspension work on high speed not so good? It looks more like scx10 suspension with \ / lower links. Or it doesn't matter? What do you think guys? |
04-01-2017, 02:16 PM | #4 | |
RCC Addict Join Date: Jan 2009 Location: Bend
| Re: rear suspension links question? Quote:
I've actually been hypothesizing over a custom build (TH based) using a chassis built around parallel, or almost parallel) lowers in the rear. With the factory tub though, it just won't happen. Sent from my SM-S975L using Tapatalk | |
04-01-2017, 09:04 PM | #5 |
Thanks for answer! Glad to know for sure that my suggestion was right. Then i dont understand why nobody made custom bild or upgrade kit with parallel lower links yet What will be your custom bild? Scaler, prerunner or rock buggy? |
04-01-2017, 09:11 PM | #6 | |
I'm not sure if I'll follow through with it or not but, I would be shooting to build a 1.9 Trophy class U4 car. Not a replica or anything like that. More of a compilation of a bunch of ideas and theories. Sent from my SM-S975L using Tapatalk | |
04-02-2017, 04:37 AM | #7 | |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
04-02-2017, 05:47 PM | #8 |
Rock Stacker Join Date: Jan 2017 Location: Adelaide
I don't know anything about roll centre, but without the triangulation in the rear you would end up with a lot of lateral flex out back. The joints would need to be designed to resist it instead. Having it triangulated helps keep things simple?
04-02-2017, 10:30 PM | #9 |
| Re: rear suspension links question? Chevy Power Manuals from MJ - Pirate4x4.com Red Star Member's Photo Gallery @ http://www.pirate4x4.com/forum/gallery Found something about roll center. ChevPowerManual07 and next pages are about linked suspension. Reading and trying to understand atm |
04-02-2017, 11:26 PM | #10 |
I understand something, in few words: Roll axis should be high. If lateral force is higher than roll axis, the vehicle will roll over. Stock vaterra rear suspension gives very low roll axis. Rear truss upgrade rises roll axis. In theory parallel lower arms will rise it even more. So 89redranger is completely right. If you want to understand why, just use my link Last edited by Pagu; 04-02-2017 at 11:30 PM. |
04-03-2017, 02:48 PM | #11 |
| Re: rear suspension links question? |
04-27-2017, 12:12 PM | #12 |
Quarry Creeper Join Date: Jan 2006 Location: bay area
rear suspension links question? - Similar Threads | ||||
Rear Suspension Question | obxbronco | RC4WD Trail Finder 2 | 15 | 11-13-2015 11:47 AM |
Integy Lower Rear Suspension Links | BR549 | Axial Yeti | 8 | 09-18-2015 05:21 PM |
vaterra twin hammers rear suspension links? | gofaster427 | Axial SCX-10 | 1 | 07-13-2014 12:06 PM |
suspension links question | idaho | Axial SCX-10 | 6 | 09-28-2013 08:28 PM |
Uneven suspension links question..... | ToTheMAXXcrawler | General Crawlers | 3 | 01-08-2010 10:06 AM |
