03-20-2017, 09:42 PM | #1 |
Quarry Creeper Join Date: Mar 2017 Location: San Diego
| Is my new TH supposed to make grinding noises?
Just got a new TH yesterday and the first time I turned it on the shift servo sounds like it's constantly spinning and grinding. I did the servo adjustment and it shift fine, but the noise never stops. I don't see any fans anywhere...
03-21-2017, 02:57 AM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: Pontypool, wales
| Re: Is my new TH supposed to make grinding noises?
It's possible that it's not quite meshing properly if you can disconect the shift rod and find the neutral position between first and second it may allow you to pin point the problem better I'd definitely check inside the gearbox tho just for piece of mind ! Sent from my iPhone using Tapatalk |
03-21-2017, 04:00 AM | #3 | |
| Re: Is my new TH supposed to make grinding noises? Quote:
I'll have to dig into it when I've more time. | |
03-21-2017, 06:01 AM | #4 |
Also possibly the shift servo hasn't been centred before installation ??? Sent from my iPhone using Tapatalk |
03-21-2017, 07:07 AM | #5 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
Read the top sticky on how to set th shift servo.
03-21-2017, 08:14 PM | #6 |
I've adjusted the shift servo, and the truck shifts fine. The shift servo though makes a continuous grinding noise no matter how I adjust the end points, and whether it's connected or not or whether I am shifting or not. I verified it IS the servo by unplugging it, which made the noise stop. I'm going to contact Vaterra and put in a warranty request, as it appears the servo is defective. |
03-22-2017, 12:59 AM | #7 |
For anyone curious, here is a video of the noise it's making. https://www.youtube.com/watch?v=PG-g...ature=youtu.be |
03-23-2017, 02:35 PM | #8 |
Rock Stacker Join Date: Jan 2017 Location: Adelaide
That's what digital servos do. More expensive ones are quieter. Yours does sound quite loud but I doubt there is anything wrong, it's just a cheap servo. That's assuming of corse the end points are set correctly. Ideally set it so there is absolutely no force on the linkage in either gear and the ball studs rotate freely with your finger if you wobble them side to side Last edited by SkiSteve; 03-23-2017 at 02:38 PM. |
03-23-2017, 03:30 PM | #9 | |
03-23-2017, 05:06 PM | #10 |
They all make some noise as the servo is constantly applying power to hold its position. My understanding is that they "hunt" slightly for the exact position so they are always twitching a little. Mine does it too but to a lesser extent. Maybe someone else can advise of a quieter servo.
03-23-2017, 05:13 PM | #11 |
Ok, thanks for the help. Fairly new to the hobby and didn't realize digital servos would do that.
04-07-2017, 11:54 PM | #12 |
Well it failed in the first ten minutes of use even with the shift points set. It would just not stop making that grinding noise no matter what i did, now it wont shift. Time to contact vaterra or Amazon.
04-08-2017, 07:53 AM | #13 |
Ok so I took the TH hammer apart tonight and it turned out the shift service didn't fail. My remote had somehow set my A switch (for shifting) to "inhibit" Once I set it back to operate auxiliary A (it's set to aux 1 2p) it works fine. But now it keeps setting it back to inhibit randomly. Any ideas? Sent from my SBM303SH using Tapatalk |
04-09-2017, 08:41 AM | #14 |
Yep, set all the settings as you want them and then re bind the radio. What radio is it, 4dxc?
04-09-2017, 04:55 PM | #15 | |
Ordered a new shift servo anyway. | |
Is my new TH supposed to make grinding noises? - Similar Threads | ||||
lcc noises | jetrod7024 | Newbie General | 7 | 03-03-2011 03:50 PM |
Noises... | Skysthelimit | Newbie General | 14 | 06-12-2009 04:05 PM |
battery noises | tdodm | Electronics | 1 | 05-15-2008 08:13 PM |
wooded noises | clodstall | Videos! | 3 | 03-25-2007 02:36 PM |
more noises | cas22 | General Crawlers | 5 | 11-10-2006 10:43 AM |
