06-12-2017, 11:44 AM | #1 |
Rock Stacker Join Date: Dec 2015 Location: Kahnawake
| Share you secret: how to make you VTH a better CRAWLER Sent from my iPhone using Tapatalk |
06-12-2017, 03:36 PM | #2 |
Rock Stacker Join Date: Jan 2014 Location: Belleville, Ontario, Canada
| Re: Share you secret: how to make you VTH a better CRAWLER
GCM front plate ( upright shocks ), GCM rear truss ( corrects link geometry ), Irie's bell cranks , locked front diff and a censored motor set up. |
06-12-2017, 10:02 PM | #3 |
Rock Crawler Join Date: Apr 2015 Location: San Marcos
The stock performance is pretty darn good, but can be made slightly better. The above post lists some good mods that will improve crawling performance. The Irie bell-crank set up is probably the single best upgrade for crawling, as it buys you all the steering you need at low speed. A different bell-crank set-up might also perform well, but I've only used the Irie set-up. The Irie bell-crank requires some front suspension system other than stock in order to mount it, so the GCM front plate or a different front shock tower will be in order if you want the Irie bell-cranks. The front shock towers that I've used really don't make the front suspension any better, but are nice because they allow a bell-crank steering mod to be installed. Also, getting weight down low will help. GCM's front shock tower allows forward mounting of the battery which helps. Some aluminum wheels, and aluminum suspension components will also put weight down low. You've already got the front diff locked and some decent tires, so you're moving in the right direction. Wet, slippery situations I'm really not familiar with, as I live and crawl in the dry, Southern California desert, and I don't drive my RCs in water. Hopefully some of the mods referenced here can help with crawling in wet conditions too. |
06-13-2017, 07:13 AM | #4 |
Mine is converted over to crawler only. Since the CG is so low, it crawls up just about anything. Great little rig. Single speed conversion (in low gear basically) 35t motor Upright front shocks and bellcranks 1 oz lead weight mounted up front as far forward as possible - battery still mounted out back. Slightly weighted beadlocks. cage trimmed out back slightly That's it. Doesn't look like this anymore, wheels and tires get changed around a bit. |
06-14-2017, 09:16 PM | #5 | |
Pebble Pounder Join Date: Nov 2016 Location: USA
| Share you secret: how to make you VTH a better CRAWLER Quote:
The Irie bell-crank set can be installed using the stock suspension. Here's mine. | |
06-14-2017, 10:15 PM | #6 |
Ah, I stand corrected. Thanks.
07-22-2017, 08:43 AM | #7 |
Newbie Join Date: Jul 2017 Location: Barboursville
| Re: Share you secret: how to make you VTH a better CRAWLER |
07-22-2017, 08:52 AM | #8 |
| Share you secret: how to make you VTH a better CRAWLER Yes sir. I just ordered the bell-crank set. I had to add a few small spacers where the top of the shock towers attach to the top plate in order to get the shocks more horizontal/parallel with the plate itself, but it was a very minor issue. See my posts starting on page 50, post #493 in the thread linked below. I also have pics of what I'm talking about. IRIE Products |
07-22-2017, 12:53 PM | #9 |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
Maybe worth considering Scorched Parts bell cranks: And the version with upright shocks and right side mounted servo for battery relocation. The battery mounted down here is a BIG improvement: The geometry of these have been carefull optimised to get the max steering angle, max suspension travel, and reduced bump steer. Top drawer performance and excellent durability from laser sintered parts. Last edited by Dbx; 07-23-2017 at 03:23 AM. |
07-24-2017, 09:45 AM | #10 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
IRIE has gone MIA so his products are no longer an option.
Share you secret: how to make you VTH a better CRAWLER - Similar Threads | ||||
Outrunners in the VTH | cooperDG123 | Vaterra Twin Hammers | 11 | 11-07-2013 06:21 PM |
FPV with a crawler...anyone?...pls share | cpmboy | Videos! | 0 | 07-27-2013 10:28 PM |
