07-04-2017, 10:56 AM | #1 |
Newbie Join Date: Jun 2017 Location: Bay Area
| Noises
My TH has recently been making a deep grinding like noise when it drives. I am not sure what it could be. If anyone knows anything about what it could be that would be helpful. Sent from my iPhone using Tapatalk |
07-04-2017, 11:16 AM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: Pontypool, wales
| Re: Noises
First thing to try ,remove the motor from the equation and roll back and forth to try and eliminate the gearbox , it could be as simple as to tight a mesh on the pinion to spur Sent from my iPhone using Tapatalk |
07-09-2017, 01:57 PM | #3 |
| Re: Noises
What if it is the motor Sent from my iPhone using Tapatalk |
07-09-2017, 03:12 PM | #4 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
| Re: Noises
Then it is, indeed, the motor.
07-09-2017, 06:21 PM | #5 |
| Re: Noises
What can I do Sent from my iPhone using Tapatalk |
07-11-2017, 05:02 PM | #6 |
| Re: Noises
Have you identified if it is the motor or the transmission? Sent from my iPhone using Tapatalk |
07-11-2017, 05:38 PM | #7 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: Noises
Gotta troubleshoot. Check and tighten your pinion. Check it's not the pinion/spur gear mesh. Try a different motor. TH RTR motor will die, only a matter of time. Could be on its last leg.
07-11-2017, 06:53 PM | #8 |
Rock Crawler Join Date: Jul 2015 Location: McKinney, TX
| Re: Noises
A single wire on my sensor wire broke recently and the motor made a grinding sound. It also got really hot really fast and cogged like mad. I thought I had destroyed a brand new motor. Once the sensor wire was replaced it was fine. Basically you have to trouble shoot RCs like a pc. Check one thing, if it's okay, move into the next. Start the parts that are easy to get to. If you're running a castle esc, listen to the beep codes. |
Noises - Similar Threads | ||||
lcc noises | jetrod7024 | Newbie General | 7 | 03-03-2011 03:50 PM |
Noises... | Skysthelimit | Newbie General | 14 | 06-12-2009 04:05 PM |
battery noises | tdodm | Electronics | 1 | 05-15-2008 08:13 PM |
wooded noises | clodstall | Videos! | 3 | 03-25-2007 02:36 PM |
more noises | cas22 | General Crawlers | 5 | 11-10-2006 10:43 AM |
