09-24-2017, 11:01 PM | #1 |
Quarry Creeper Join Date: Apr 2017 Location: Melbourne Australia
| RIP - Shift servos I have killed
So far using the attached linkage setup and EPAs set. 1x Thunder Tiger 1510mg 1x Hi-Tec HS5645mg Should I get something with 270oz-in or more torque?? Im fairly hammering a quicrun 13.5t sensored brushless and the vicious drag brake of the mamba X. Sent from my Pixel using Tapatalk |
09-25-2017, 12:37 AM | #2 |
| Re: RIP - Shift servos I have killed
Try using a longer rod and springs on both sides.
09-25-2017, 02:57 AM | #3 |
| Re: RIP - Shift servos I have killed |
09-25-2017, 04:31 AM | #4 |
I haven't gotten my hands on mine yet. But would a normal 1:10 servo saver mount up and then have the linkage solid? I've got a couple from my RTR crawlers.
09-25-2017, 04:41 AM | #5 |
The issue with the standard setup for me at least when using the full size servo is getting the shift Shaft to move in a straight line. Mine using the standard setup for push the shaft to the left which would add so much drag that it wouldnt shift. So I came up with the pivoting rod support. Which is much like an Ofna nitro throttle horn. But I just didn't want to pay for it. Sent from my Pixel using Tapatalk |
09-25-2017, 05:59 AM | #6 |
Flip the servo so that the angle of the rod is reduced by being longer and further away from the actuator. Maybe. I see what you're saying about the pivot piece. I can't get HobbyKing to load on my crappy wifi at work. But what about a linear type servo for a landing gear or retract on an airplane?
RIP - Shift servos I have killed - Similar Threads | ||||
are the shift servos fine on.... | twisted | Traxxas TRX-4 | 3 | 07-18-2017 05:50 AM |
killed 3 servos....now what? | GSRswapandslow | Electronics | 19 | 05-12-2009 08:44 PM |
Help!Help! I think I killed it | SouthernHighLife4x4 | General Crawlers | 11 | 06-04-2006 09:48 PM |
