Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: 2 early VTH RTR. Need advise
Old 01-01-2018, 11:29 PM   #1
Default 2 early VTH RTR. Need advise
So, a few years ago, I bought both my daughters there own twin hammers. They have both been problematic with all the known issues. One daughter is completely uninterested and one is still kinda interested.
I have one in running condition but the trans doesn't shift right, the other has a busted front diff, didn't shift right and the steering servo is toast I think.
So, I'm willing to spend the coin to turn these both into solid runners but have been out of the game for a while. Can someone offer a list of what I'd need to build 2 solid all around rigs. I know vanquish and GCM are 2 names I've come across for building these up but I think I need to start from the electronics up. Would be mainly bashing with a hint of scale look. Any help would be appreciated.
Thanks
apextrans is offline   Reply With Quote
Old 01-02-2018, 12:05 AM   #2
Default Re: 2 early VTH RTR. Need advise
LOL. Follow his lead: bilinvic's Twin Hammers
The GCM parts are scarce but you may be able to find them. Or message onecool54@yahoo and he had a small stash of Derwood vertical front mount plates. Maybe has a couple left. They're a simple design but a PITA to bend right. You may wanna ditch the 2 speed as well and eliminate that headache.
Brake Weight is offline   Reply With Quote
Old 01-02-2018, 07:30 AM   #3
You can still get GCM's Front plate from their web store ( GCM Webstore Canada International - Vaterra Twin Hammer Buggy ) and body parts from their Shapeways store ( https://www.shapeways.com/shops/gcmracing ).
While you're on Shapeways, check out Scortched Parts, they have some interesting steering and front suspension parts for the TWH and a steering rack for the GCM front plate. ( https://www.shapeways.com/shops/scorched_parts )
I'm sure there are other suppliers, but can't think of any right now, morning coffee comes before brain is fully engaged...
Good luck with the rebuilds.
Bl-air is offline   Reply With Quote
Old 01-02-2018, 11:45 AM   #4
Dbx
Sounds like you don’t need to worry too much about chassis mods to get you going. The upright shock mod is not something that really ‘needs’ doing.
For the electrics your choices are set by budget. If you think you are going to get lots of use out of the rigs - splash the cash. Going home early with a broken rig is no fun.
As a brushless motor enthusiast, i’d recommend the latest castle creations sensored combos. If it’s any where near your price range, you won’t be disappointed. Great for crawling, great top speeds, waterproof, durable and good customer support.
I have the mamba x and 3800kv ‘slate’ motor - it’s perfect for the twins.
The Mamba X is good because you won’t need a seperate BEC to run the steering servo - saving cash and complexity.
I’ve found the TH is not really that steering servo ‘hungry’. Whilst my Wraith with 2.2 size wheels eats good servos for breakfast, the TH demands less. I’s say any steel gear servo in the $80 - $100 is going to be more than adequate.
Dbx is offline   Reply With Quote
2 early VTH RTR. Need advise - Similar Threads
VTH trans Thickone Vaterra Ascender 4 08-01-2017 10:25 AM
VTH Electronics/Upgrades? Weichert crawling Vaterra Twin Hammers 4 02-14-2016 07:54 AM
Outrunners in the VTH cooperDG123 Vaterra Twin Hammers 11 11-07-2013 06:21 PM
