Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Rear wheel drive only..front not moving.
Old 01-02-2018, 02:22 PM   #1
Default Rear wheel drive only..front not moving.
Hello,
Rookie here, just bought myself a used TWH DT 1.9, looks great but something is not working as intended. The front wheels are not spinning when applying throttle, only the rear wheel.s
I can see the front shaft spinning but as I said, no movement on the front wheels.
I presume it's the something with the front diff? Perhaps some of you can help me out. Have a stripped screw head I need to remove in order to get the body off. In the meantime I hope to get this thread going.
Thanks.
/hj_swe
hj_swe is offline   Reply With Quote
Old 01-02-2018, 02:35 PM   #2
Dbx
Default Re: Rear wheel drive only..front not moving.
Could be diff.... but check the screws on the drive shaft ends. They do come loose sometimes.
Dbx is offline   Reply With Quote
Old 01-02-2018, 03:54 PM   #3
Yep. Two set screws.
Brake Weight is offline   Reply With Quote
Old 01-04-2018, 01:32 AM   #4
Thanks guys. That solved it. Should those screws be set with locktight?
I'm missing the manual.
/H
Old 01-04-2018, 01:40 AM   #5
I did mine with loc tite. If you're carefull you can drill through the output shaft and use a longer style grub screw all the way through it.
Old 01-05-2018, 07:27 PM   #6
/H
Yes. Blue loctite is best.
lonleycreeper is offline   Reply With Quote
Old 01-10-2018, 02:52 PM   #7
Natedog's Avatar
X2, use a q-tip with rubbing alcohol to clean up any oily residue first.
Old 01-12-2018, 05:42 AM   #8
You guys where right, it was a combination of set screws!
Both the screws on the Drive shaft and the Drive Shaft Yoke/Cup was loose.
Some blue lock tight took care of that.
Rear wheel drive only..front not moving. - Similar Threads
Ever tried to drive on rear wheel drive only? 8000ft Axial Yeti 6 05-15-2016 07:49 PM
Strengthening Rear Shock Mounts After Moving Battery Up Front Brickman Axial Wraith 9 02-01-2015 05:56 PM
Over drive front or Under drive rear? o0wiz0o Axial SCX-10 14 04-29-2013 01:25 PM
Over drive front of my JK and underdrive rear MikeJordan Axial SCX-10 7 04-17-2013 07:24 AM
