Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: High Gear Issue
Old 01-22-2018, 10:23 AM   #1
Default High Gear Issue
I just brought my original RTR TH out of the dust and when I powered i heard some major grinding, then just motor spin. Low gear works fine, but just spinning on high... If I pick up the vaterra metal trans gears, do you think that will have everything I need to fix? Tks.
tomasw1 is offline   Reply With Quote
Old 01-22-2018, 10:41 AM   #2
Default Re: High Gear Issue
Double check your shift servo end points are set properly. It sounds like maybe it is sticking in neutral instead of going to high gear.
Sent from my Pixel using Tapatalk
Damatheus is offline   Reply With Quote
Old 01-22-2018, 12:43 PM   #3
You rock... That was it. Thank you!
Old 01-22-2018, 03:33 PM   #4
Welcome!
Be aware the v1 twin hammers had issues with the servo end points. The settings on the remote were easily knocked out of spec, so check them frequently if your still using the older style controller.
Old 01-23-2018, 09:45 AM   #5
Yes, that was the cause of my issue. I bought a DX5C and set the initial endpoints ultra conservative. I also made the mistake of thinking the endpoints would be an equal percentage. FYI - In my case, they were not. 28 and 35 percent before I heard any servo buzz. Tks again.
High Gear Issue - Similar Threads
Bomber gear issue raddad1975 Axial RR10 Bomber 13 03-26-2017 09:45 PM
VP high steer clearance issue? Dreamwerkz Newbie General 2 02-09-2014 04:21 PM
gear issue Kratos General Crawlers 0 05-07-2011 08:34 PM
AX10 shift kit or shifting from Low gear to High gear? legobrains Axial AX-10 Scorpion 19 10-27-2007 12:24 AM
stall - surging issue when in high? Rc_Kid General Crawlers 17 03-13-2007 05:38 PM
