Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Electronics
Thread: Team Brood Ruby Red Limited Edition 35 Turn Epoxy Balanced HHK Slotted Armature!!!
Old 07-26-2012, 01:31 PM   #1
Default Team Brood Ruby Red Limited Edition 35 Turn Epoxy Balanced HHK Slotted Armature!!!
For all you guys loving the Red parts on your trucks, these motors feature a Ruby Red can with High Power TDK FB9 magnets
This Limited Edition Features a new for crawling feature of a slotted armature. Years ago, Marc Rheinard used an armature like this to win the Touring Car World Championships. The slot in the arm basically frees up the arm as it rotates through the magnetic field. In crawling it will mimick a 4 magnet can to a degree, but you won't lose as much drag brake as you do with a 4 magnet can....since the arm has less steel, there is a little loss of torque, but they produce more overall power.
I've gone over the benefits of a HHK before, so I will save most of my breath....basically, more copper....MORE power, torque, and RPM.
Also, having gone over Epoxy Balancing before, these are Epoxy balanced so we are NOT removing any more steel, as with the slot a decent amount has been removed already.
Only 20 Motors are being made, Sold in Pairs only... 10 pairs.....10 lucky souls!
Motors are Stamped on bottom, Forward (F) or Reverse (R). One motor is wired in reverse for the axle that needs it.
Shaft is engraved with wind.
Motors are Matched for Maximum Performance...Dyno tuned to be in sync with each other.
Limited Edition Stickers
Here are the specs
2 Magnet High Torque Can
729 Standup Brushes
5mm Slotted Armature
Epoxy Balanced
7.5mm Comm
35 Turns of 20.5 AWG Wire
$169.99 plus Shipping $7 shipping in the USA (international rates vary)......First come first served!
Order Here!
Team Brood Racing :: Crawler Motors :: Handwound Motors :: Team Brood Ruby Red Limited Edition 35 Turn Pair
EddieO is offline   Reply With Quote
Old 08-23-2012, 05:13 PM   #2
Default Re: Team Brood Ruby Red Limited Edition 35 Turn Epoxy Balanced HHK Slotted Armature!!
Just ordered a set, can wait to pit them in. They should have a good bit more wheel spin compared the 35t hhk-t 10mm high fill broods correct ?
irokcrawl is offline   Reply With Quote
Old 12-04-2012, 12:26 PM   #3
Got them in the mail this morning. Thx Eddie
-NB- is offline   Reply With Quote
Team Brood Ruby Red Limited Edition 35 Turn Epoxy Balanced HHK Slotted Armature!!! - Similar Threads
Team Brood Scaler V2 Limited Edition 35 Turn Epoxy Balanced HHK Slotted Armature!!! EddieO Vendors Electronics 9 07-01-2013 02:31 PM
Team Brood 2012 Limited Edition #1 35t Double! EddieO Vendors Electronics 13 03-21-2012 01:05 PM
Team Brood 2011 Limited Edition #1 EddieO Vendors Electronics 19 02-27-2011 07:21 AM
Final Team Brood Limited Edition of 2010 35T DOUBLE! EddieO Vendors Electronics 26 01-30-2011 08:17 PM
You may edit your posts
