08-30-2017, 10:34 PM | #21 |
Pebble Pounder Join Date: Mar 2016 Location: Mountains
| Re: Heyok: Rock Lights on a budget
Hi, I just bought the 3s rock light kit from RPP and had a question. I had bought 2 of your toggle switches from you and use them for my other lights and wanted to know if I can plug the rock lights into one of them instead of a receiver port? Also why do they need two power sources. I mean if the esc powers everything else why do I need to connect to the battery, wouldn't the esc be enough? Just trying to understand this stuff still learning so forgive me. Thank you. oh and by the way I love the toggles I got from you they are perfect for my appilcation. |
08-31-2017, 05:31 AM | #22 | |
| Re: Heyok: Rock Lights on a budget Quote:
If it is this item then yes, you could use it to work the rock lights and some other servo - one at a time depending where the toggle is pointing: Servo Toggle Switch Why two power connections? When you plug into a receiver, the receiver supplies 6 volts (usually) to the item you have connected, but the rock lights operate on 12 volts... it gets that voltage from the battery. Elsewhere in this thread I mention that I build a version of this part that will run on a lower voltage than 3S. If you wanted to, you could power it from the receiver in order to step up the voltage to about 12 volts to light the rock lights, so again you are probably wondering why I have the connection for external power and not power from the receiver. That's because not everyone has a good supply for their receiver power (a strong internal BEC or external BEC). Taking this power from the battery bypasses that need. Hope that answered you. If not, let me know where I can provide more detail. Al | |
08-31-2017, 11:01 AM | #23 | |
08-31-2017, 11:26 AM | #24 | |
09-01-2017, 12:10 AM | #25 |
| Re: Heyok: Rock Lights on a budget |
09-01-2017, 04:55 AM | #26 |
| Re: Heyok: Rock Lights on a budget Extend them as much as you like, that would be fine.
09-04-2017, 04:22 PM | #27 |
| Re: Heyok: Rock Lights on a budget Ok sorry one more question concerning the rock lights. Would it be possible to tie them into the power wires for my bec instead of to the esc wires( dont want to tear apart the plug wires cause their not my best soldier job lol and dont want to make it worse).Figured I could splice both power wires together without as much hassle.
09-04-2017, 04:27 PM | #28 | |
09-04-2017, 04:45 PM | #29 |
09-04-2017, 04:51 PM | #30 |
Welcome!
09-04-2017, 07:47 PM | #31 |
Well, I broke one I guess. Got everything hooked up and mounted with no problems, plugged in my battery and only had 3 working. I some how managed to break the wire off of the led. So now gonna order another set lol
09-04-2017, 07:57 PM | #32 |
Heyok: Rock Lights on a budget - Similar Threads | ||||
LED lights on a single HeyOk switch | SoCal_80 | Axial Wraith | 2 | 01-25-2015 08:24 PM |
Newbie to this forum. Rock Crawler, Low Budget | Ian78 | Chit Chat | 5 | 02-09-2013 08:31 PM |
Rock lights anyone? | m4rK | Traxxas Crawlers | 6 | 09-07-2011 06:07 PM |
buiding a rock racer on a budget got some ? | canadianjeeper | Newbie General | 2 | 02-06-2008 10:54 PM |
