05-17-2009, 06:43 PM | #21 |
Quarry Creeper Join Date: Feb 2009 Location: In The BackYard Crawlin
the 4-40 are for the ball ends and will thread in a 3mm shaft.
05-21-2009, 01:01 PM | #22 |
Pebble Pounder Join Date: Apr 2009 Location: Gresham
Allready been talked about but here are some picks anyways. About 1/2 inch cut away from the ax10 Integy driveshafts. Last edited by PDXFNG; 05-21-2009 at 01:09 PM. |
05-21-2009, 01:59 PM | #23 |
Rock Crawler Join Date: Apr 2008 Location: Greentown
great thread! Im about to put some Traxxas drive shafts on, the stock pins dont like to stay in...
05-21-2009, 03:20 PM | #24 |
Rock Stacker Join Date: Mar 2009 Location: SGV, LA, CA, US
I ended up going with the traxxas 12 pack of rod ends definately good to go!!! The integy driveshaft is cool too. |
05-21-2009, 07:12 PM | #25 |
Pebble Pounder Join Date: Dec 2008 Location: Cen Cal
Heat shrink the stockers
05-21-2009, 08:18 PM | #26 |
| I tried that and it worked somewhat. Had to keep doing it every few hours of drive time. I guess maybe I'm just rough on stuff. My problem was that the pin kept poping out of the plastic shaft even though the set screw did its job. Personally, I just think maybe the pins were just a tad on the short side but I found these at my LHS and it was the last set they has so I thought I would give it a go. Plus the setscrews are larger and easier to find replacements (at least for me).
05-27-2009, 07:58 PM | #27 |
Newbie Join Date: Nov 2008 Location: US
awesome info in here
03-23-2010, 08:35 AM | #28 |
Pebble Pounder Join Date: Jan 2010 Location: Near the ROX BOX
Bump... Lets see what else you guys have found crosses over. |
04-10-2013, 02:47 PM | #29 |
Rock Stacker Join Date: Jan 2013 Location: Latvia
| Re: Cross Reference Parts
Hi! Didn't want to create a new thread on the same topic, so I dug up this one. Does anyone know if the creeper axle parts (like C hubs, knuckles) fit on the scx10 axle? |
04-10-2013, 03:35 PM | #30 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
knuckles will, I don't think the chubs will though.
04-10-2013, 05:49 PM | #31 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
Chubs on creeper are hex, the scx ones aren't. I also found out that the bearings are separated just a tiny bit more on the creeper knuckles which makes getting the pin in there using the SCX stub axles difficult.
04-11-2013, 08:01 PM | #32 |
Newbie Join Date: Feb 2013 Location: Upstate
Too bad most of the pictures have been moved or deleted now that the Creeper has been discontinued. Now more than ever is this thread going to be a good reference point.
