02-04-2011, 06:51 AM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: lakeville Mn
| Shock spring Question?
My stock Venom seems to hang up alot(on the center skid plate) compared to my honcho and mini losi crawler. Due to the venom body being longer and dosen't sit as high. What Shock springs should I run on the stock shocks to lift it and gain more clearance, Thanks
02-04-2011, 07:15 AM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: Phelan California
Personally I put on a Paradox skid and left the over all height the same. You should check out the threads by rmdesignworks he has addressed most issues we have with our creepers
02-04-2011, 07:20 AM | #3 | |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
second...are you still running the internal springs too? are you using the stock shock oil in the kit? The Creeper has an inherent problem with hang up on the skid and it wont matter how high you jack it into the air it will still hang up...thats why I make the Flex Skid. I run one of the tallest Creeper's youll ever see with a Flex Skid because without the FS it hangs up. | |
02-04-2011, 07:35 AM | #4 | |
02-04-2011, 07:55 AM | #5 |
......on the Creeper wagon
02-04-2011, 08:17 AM | #6 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
| ++++++ ON RMD'S SKID, NO HANGUPS!
02-04-2011, 10:12 AM | #7 |
Pebble Pounder Join Date: Nov 2009 Location: joliet
thats funny cuz in his video on youtube he gets hung up like 10 times. with all do respect rmdw i would rather learn how to position my rigs rear tires and actually walk up the rock rather then flooring it and wiggling my tires. that flex skid is only and crutch and in my world should not be legal.
02-04-2011, 10:40 AM | #8 | |
The nice thing is...you can choose not to use one. Yours is the first negitive opinion Ive heard. How many times have you comp'ed or been to a comp in rc? How much 1:1 wheeling have you done? I ask because if you are experienced in either you know that wheel speed and wiggling the tires are things you do to make your rig go where you want it. They are control techniques. Last edited by rmdesignworks; 02-04-2011 at 11:11 AM. | |
02-04-2011, 11:10 AM | #9 |
Starting to get a little off topic, My main question was what brand or size shock springs people were running on there rigs. Using the original shocks to get more clearance. To each there own as to what is legal and not or if something works or doesn't, Isn't it all about having fun? Man, I don't see anything good coming from negative comments. Hopefully You run what your happy with not what you think is cool because someone else likes it. |
02-04-2011, 11:15 AM | #10 | |
RCC Addict Join Date: Apr 2010 Location: Ringwood
02-04-2011, 11:27 AM | #11 | |
02-04-2011, 11:32 AM | #12 |
02-04-2011, 11:33 AM | #13 |
a skid plate is factory equipment as is a dig unit. your flexi-pad is a crutch because its a tool(a device used to achieve something or help aid in a process) a crutch aids in walking, therefore a crutch falls in that category. zero - 1:1 wheeling fifteen(or so) - local comps THINKFORYOURSELF LIQUIDKOOL |
02-04-2011, 11:34 AM | #14 | |
02-04-2011, 11:39 AM | #15 |
before you do anything else remove the internal springs
02-04-2011, 11:42 AM | #16 |
02-04-2011, 11:43 AM | #17 | |
http://www.youtube.com/watch?v=KAIAelU3ILo wheel speed and launching happens as much in the 1:1 world as it does anywhere in rc. and in all the comps you have attended and ran in you have never burped the throttle or wiggled the tires to adjust the attitude of your rig. The dig is an aftermarket item you add and most Pro drivers I know say the dig is a crutch...if you want to call my Flex Skid a crutch,,fine. But you wont survive the comps I run in if you rely on your ability to align your tires for the next gate....good luck with that. | |
02-04-2011, 11:55 AM | #18 |
| the internal springs serve a couple of purposes. To help control the rebound of the shock and to limit the compression/extension speed. It also makes the shock run at about 50/50 or 60/40 droop/sprung instead of allowing the full extension of the shock. The internal spring pushes the shock piston down which makes the rig ride lower.
02-04-2011, 12:03 PM | #19 | |
Obviously you know your _hit, Is it difficult it to do this. Got this Crawler already assembled 2nd hand, so I don't know what I'm getting into as far as taking apart the shocks. Never assembled or disassembled shocks before. | |
02-04-2011, 12:06 PM | #20 |
| hang on a minute,,let me look at your OTHER thread...<---gotta do it man sorry.
