Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Venom Creeper
Thread: 1qwkfox's Creeper.
Old 04-18-2011, 06:34 PM   #21
Dude that's crazy! Cant believe it will hang on like that!
cumminsontherocks is offline   Reply With Quote
Old 05-11-2011, 06:30 PM   #22
Finally got an fw/rv esc on theway (OG rooster crawler) , an got a servo in .
Also started to make my own BTA steering setup , based off of RMD's design.
This is my first attempt , so some changes maybe be made.
( it obviously needs to be trimmed,cleaned up , rounded corners , counter sunk screws )
1qwkfox is offline   Reply With Quote
Old 05-11-2011, 08:32 PM   #23
looks good i still run chisels but i think the carcus is a little thin so there not great like the pitbulls but the sedonas have a thicker carcus and they sidehill better but think sedona sidewalls and chisel tread mmmmmmmmmmm!!!!!!!!
asw27x is offline   Reply With Quote
Old 05-11-2011, 08:57 PM   #24
Thanks , I picked these up for $10 in the FS section. If anything they're better than stock an will work for now till I can get some white dots.
Hopefully some more money will get free'd up here soon so I can buy more stuff when I want to like was orig. planned, not just every now an then.
Old 05-11-2011, 09:02 PM   #25
Yashua
CREEPERBOB's Avatar
Its gettin' there, that btl plate looks good but the material looks to thin, there's alot of tourqe applied to the plate when its that high above the mounting hardware.
CREEPERBOB is offline   Reply With Quote
Old 05-12-2011, 04:27 AM   #26
Thanks , yea its 14g 304 stainless it is pretty stout stuff. I am thinking about making a new one with less of a bend to clear the link bars.I can goto 12g Stainless if I have to or even 1/8" alum.
Old 05-16-2011, 06:57 PM   #27
Got a couple more updates , got the electronics in .. using a loaner TX/RX until I find something 2.4.(thanks to cumminsontherocks).
Other then that , this is where I am at. I also have a Aluminum servo horn I have tried Hitec/Futaba , looks like I am going to have to try an JR and hope it fits.
Oh , also going to make some cross braces and maybe shock relocators at work tomorrow I hope.
Old 05-16-2011, 07:24 PM   #28
man that servo is siting high make sure you get a long servo horn. looks good though let us know how it works
jojo303d is offline   Reply With Quote
Old 05-16-2011, 07:43 PM   #29
yea, from the looks of it you have some room to either bend the servo plate down or place the servo on the bottom side of the BTL plate.
venomcrawlerdud is offline   Reply With Quote
Old 05-16-2011, 08:26 PM   #30
is it just the pix, or is this pig painted some kind of candy fucia?
rybredd is offline   Reply With Quote
Old 05-16-2011, 08:55 PM   #31
no rybredd, i looks like is some kind of light metal flake green or something.
Old 05-17-2011, 03:14 PM   #32
Yes its a metallic green and all of the RED is factory from Venom, Thanks for the tips on the servo plate I am trying to base it off of RMD's kinda hard to get angles/placement and what not by looking at pictures.I'll adjust accordingly once I actually get it up and going.
I can always make a new plate at work or just buy one from RMD if this one doesn't work out.
Old 05-17-2011, 03:19 PM   #33
I think the " L" shape that is making it so high.
I have 1.5" in the plate .25" in the "L bend" ( + 1/16ish per bend) then to a 45* bend , total length being X" to start before trimming.I may make one without the "L" if need be.
