05-20-2011, 07:10 AM | #1 |
Quarry Creeper Join Date: Apr 2011 Location: Canada
| just got a new creeper
So i just got a new creeper, a venom 550 motor, a vrt3 fm radio, and a chepy redcat esc but it should do the job. Iooked at the instruction book last night and its seems easy to follow. I havent even cracked the plastic on the parts yet. Is there anything i should know BEFORE i start building? I noticed alot of after build mods and stuff, but i was just wondering if anyone had one of those "wish i knew that before i built it" moments?
05-20-2011, 08:20 AM | #2 |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
the only thing i can thick of, is put the motor in wail you still have acess to the trans.
05-20-2011, 08:22 AM | #3 |
| Install the motor and set your pinion mesh before you build the rest of the truck. The instructions tell you to install it after everything is built, and that's a bit of a pain. Pay attention to your CVD's (I believe Venom calls them VCD's). My pin was binding on one side, so I cleaned it up before going any further. Get a set of Paradox pin locks too (I think that's what they are called) from RockyMountainDesignWorks. The pins sliding out can cause all kinds of problems. Read RMDW's Tips thread before starting. Good luck and welcome to RCC |
05-20-2011, 09:35 AM | #4 |
Quarry Creeper Join Date: May 2009 Location: melbourne/palm bay
take your time, and be careful with the shock caps... ++++++1 on putting the motor in on the first chance you get!!!!!!! Save yourself from punching yourself in the face!!!!! |
05-20-2011, 11:00 AM | #5 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
read the tip and tricks thread before starting
05-20-2011, 09:16 PM | #6 |
Newbie Join Date: May 2010 Location: Steamboat Springs
Get a nice set of hex drivers. I put mine together with crappy tools, and it took way longer than it should have.
05-20-2011, 10:34 PM | #7 |
Pebble Pounder Join Date: May 2010 Location: Indianapolis
read the tips and tricks. JB weld the diff gears that will save you some heartache later on. eliminate the battery tray and go for a stage II type setup. CkRC http://www.ckrccrawlers.com/ckrcs-ve...it-p-1641.html that should get you started. |
05-20-2011, 10:44 PM | #8 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
for sure read the tips and tricks section and rmdesignworks thread . oh and since you started a thread keep it use it as a build thread and a question thread , please don't put every question in a seperate thread . |
