06-18-2012, 09:41 AM | #1 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
| 73' Bronco-MOA to Creeper conversion
last week I sold a pick-up, part of the deal was for a newly build, never run creeper with a crawler master-L motor. so over the weekend my rs10xt based scaler got converted to a true shafty. getting ready to order a ESC for the CM-L. i did mod the adapter plate to accept a 380 can off the redcat, but it's just not enough motor, was able to run it enough to know that this was the right move. I will post some pics of the conversion tonight, for now, here is my MOA build thread. http://www.rccrawler.com/forum/redca...xt-bronco.html |
06-18-2012, 12:35 PM | #2 |
| Re: 73' Bronco-MOA to Creeper conversion
ordered a brushlesshobbies 120A ESC, a set of 2s2p 6000mah hardcase lipos and another ECO6 charger (just gave mine to my dad, i love this charger, cheep and does a nice job). this thing will rox my sox.
06-18-2012, 03:40 PM | #3 |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
Wheres those pics??? I followed your thread in the 2.2 scale I think it was or maybe it was in the RS10. Either way your rig was sexy Last edited by mgputer; 06-18-2012 at 03:49 PM. |
06-18-2012, 09:25 PM | #4 |
I was fighting with a couple of computers and a android phone all evening. Might be the same tomorrow night too.
06-19-2012, 05:09 AM | #5 |
Work in IT I take it? I do too....even when I am not at work I end up knee deep in routers and pc's at night.........
06-19-2012, 07:17 AM | #6 |
I tried installing win 8 on both of my media computers at home, the 64 bit unit down stairs works great, drivers loaded right away. our internet is screwed (Cox) so i have been tethering to my phone. turned on the hot spot and watched about half of this weeks true blood and the 3G dropped. now when i turn on the hotspot, i loose 3G, when i turn it off, it comes back. so i tired to install PDAnet, PC app will not install on win8 64 bit. moved up stairs to the 32 bit, it loaded fine except no audio!?!? installed PDAnet, works great there. installed connectify to back feed the signal to my tablet so i watch BSG. connectify no longer allows you to share from anything but the Ethernet in the free version..........WTF good is that!?!??! so, I ended up giving in and watch BSG on my phone, PITA.
06-19-2012, 08:34 AM | #7 |
I tried Win8 for a bit but switched back until it gets a few updates and other apps start getting the proper drivers. To much of a pita to be worthwhile atm. Have you tried the compatibility mode to see if that pdanet will work that way? That helps alot with some apps.
06-19-2012, 08:44 AM | #8 |
yeah I did, it just would not install the phone driver on 64 bit. our interent should be fixed today, though now I think I need to redo the routers. I like the interface for a media center. 46 inch flat tv with metro works nice, would be even better if i can get my xbox controller to move the coursor. though after this fall i doubt i even need a computer seeing as Xbox is adding IE.
06-19-2012, 03:01 PM | #9 |
Back on topic here, has anyone done a remote motor mod. not even sure of the right term. but i have my trasnfer case mounted centrally and I am thinking about trying to mount the motor up under the hood. wasn;t sure if there was an adapter made for this.
06-20-2012, 08:20 PM | #10 |
| Re: 73' Bronco-MOA to Creeper conversion So there it is. |
06-21-2012, 05:34 AM | #11 |
For a crawler motor that thing is really big. Rig is looking good. Very unique way of mounting the trans I like it! Can't wait for more updates! As for the moving of the trans you can yes. RC4WD has a transfer case you can use in the center then you put the trans and motor under the hood with a driveshaft running from the trans to the transfercase. If I remember right the transfer case runs around $70-100 depending on which one you get. You will need new longer shafts though as the tansfercase is really small but that really isnt an issue as the shafts should be replaced anyway. Alot of guys run those because they are required for class 1 comps. The one I would use is the killer. Fits in sideways for more room. http://store.rc4wd.com/Killer-Transfer-Case_p_858.html Last edited by mgputer; 06-21-2012 at 05:43 AM. |
06-21-2012, 07:28 AM | #12 |
well I was looking more at keeping the transmission where it is and then remote locating the motor. not a big deal, more looks than anything. the motor came with the creeper, so I am going to run it. it;s like a 27t and as long as it is, i think it will have a ton of power, just hope it is not too much and starts tearing up the transmission. this build went from a laid back weekend family fun to super serious over night. I am really interested to see what she does. stopping to get a smaller enclosure tonight, hope to start re wiring it and maybe have it running by Sunday if time allows, been busy ever night for the last 3 weeks, so we will see.
06-21-2012, 08:43 AM | #13 |
Looks real good wolf, very unique scale build. Can't wait to see how you go with motor re location...
06-21-2012, 09:54 AM | #14 | |
| Re: 73' Bronco-MOA to Creeper conversion Quote:
i may leave it, if there is not already an adapter plate out there, i don;t want to screw with trying to fab one. i got a set of 2s2p 6000 mah lipos coming, i think one of those will sit nicely length wise under the hood. this build is super close to being done with the fab phase. already planning the next one based on my rs10 axles, this will be a much better use of them. http://www.rccrawler.com/forum/redca...air-tuber.html | |
06-21-2012, 10:28 AM | #15 | |
Its one less drive shaft to break also. Thats why I kinda decided against it as well in my upcoming build of a 34 ford truggy. Should have it started next week sometime. | |
06-23-2012, 09:19 PM | #16 |
New pics taken, but my page keeps crashing before i get them posted, so check out my photobucket. http://photobucket.com/moascaler Still need to run the batery leads and firgure outthe power switch, may just leave it on and un plug the battery. also waiting on my programer, it didntget putin the box at brushles, no biggy, $@#% happens. So far though, i like it. |
06-28-2012, 07:39 AM | #17 |
let a buddy tool around with the Bronco last night, he got all excited about it being able to push it;s way through the alfalfa and well, now the diffs click. the slides don't look like they have moved, but i am hoping that is the issue. going to bust them open tonight and well most likely do the JB putty mod.
06-28-2012, 06:39 PM | #18 |
..................is it normal for teeth to shear off the pinions before one pack is ran through???
06-29-2012, 07:02 AM | #19 | |
Umm no. Out of all the threads in here I don't remember seeing anyone even break a pinion. If you have your receipt email venom. They are really good about replacing parts. Also it doesnt matter where you got it even ebay. If they were new when you got them they will replace it. I broke an axle first time out with mine and I bought the axles off ebay. Within 3 days I had a new set of axles in the mail. They told me there was a bad run of axles that were breaking easy so thats why they sent me a set of 4. Maybe there was a bad set of gears as well? | |
06-29-2012, 07:27 AM | #20 |
well i got the truck in a trade, so it was assembled by someone else but never run till I got it. i haven't opened the rear housing yet, but it is popping the same way the front was. I decided i wasn't going to wait on trying to get replacements from venom, found a place on ebay that has the ring and pinion for 10 bucks a set and ordered 4 with expedited shipping. I have a crawl i am hosting on the 7th, would suck if i couldn't run at my own event LOL. it does seem very odd, the ring has no damage at all, but the pinion was missing about half of it's teeth. the little bit of Assembly grease that was in there grabbed the pieces and was holding them against the housing. I am thinking bad heat treat on the pinions, they just seem too brittle. though i think this is cast part, so it could just be a bad casting too.
73' Bronco-MOA to Creeper conversion - Similar Threads | ||||
73' Brocno -MOA to shafty conversion | Docwolf | 2.2 Scale Rigs | 1 | 05-30-2012 12:08 PM |
Creeper Crawler conversion Safari Creeper | Grumpster1980 | Venom Creeper | 25 | 02-24-2011 07:57 AM |
My 73' Bronco | geekfreek95 | Losi Micro-Rock Crawler | 6 | 10-01-2010 09:01 PM |
My little 73' Bronco micro | drtrydr2000 | Micro Scale Rigs | 11 | 09-23-2010 03:51 AM |
creeper x trail conversion | twilight | Venom Creeper | 4 | 10-27-2009 07:11 PM |
