Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Venom Creeper
Thread: Cvd rebuild help
Old 02-21-2013, 06:37 PM   #1
Default Cvd rebuild help
I have a set of creeper axles that I want to use on a project but my front axle is missing the parts of the Cvd that join the two axle parts together......the little pin and the piece it slides into...not sure of their exact names. Does anyone know where I can find these parts?
ON THE ROCKS is offline   Reply With Quote
Old 02-21-2013, 09:20 PM   #2
Well... Cheapest route, if you have access to A welder or know a welder.. pull ur rear axles out, make a jig, lay the axle shaft an stub shaft into the jig an weld em together. Making sure they stay straight.. the you have locked rear straight axles an use the rear axles up front... BAM
winnerone23 is offline   Reply With Quote
Old 03-26-2013, 01:29 PM   #3
Default Re: Cvd rebuild help
For the pin..i used either linkage rods for rc airplanes 2-56 diameter works in mine..and have used broken drill bits of the same diameter just cut them to length with your dremel cutoff wheels..
mikejhs1982 is offline   Reply With Quote
Old 03-26-2013, 03:31 PM   #4
the collar can be replaced with heat shrink. there are 5 total pieces to one CV, do you have the Ferrell that the pin goes through inside the ball? it is threaded and you can run a small set screw in to hold the pin if you don't want to run the collar.
Docwolf is offline   Reply With Quote
Cvd rebuild help - Similar Threads
CVD Rebuild? Man of 5lay Venom Creeper 14 06-07-2011 10:22 AM
CVD Rebuild kit for creeper information here! Twiztid Metal Venom Creeper 1 06-03-2011 03:26 PM
cvd rebuild help goobs General Crawlers 4 01-17-2011 09:27 PM
MIP CVD rebuild kit? av8rds Team Losi Comp Crawler 4 11-14-2009 10:06 PM
HTML code is Off
