Go Back   RCCrawler Forums > Competitions and Events > WRCCA > WRCCA Rules
Thread: sportsman question
Old 12-20-2011, 08:24 PM   #1
Default sportsman question
I've been thinking about doing another Sporty for the upcoming spring season. I've run it before and it was a lot of fun before everyone starting to disable the DIG on their comp rigs and ruining the intention of the class. I have a design on paper that would basically have a lockable center diffy inside of a transmission.
What would your opinion be on the legality of such a beast. It would not /could not have a dig function but it would certainly add a steering advantage by allowing the front and rear driveshafts to turn at different speeds then be mechanically locked for max. traction.
BigSki is offline   Reply With Quote
Old 12-20-2011, 08:25 PM   #2
MODERATOR™
EeePee's Avatar
Default Re: sportsman question
Two channels only.
EeePee is offline   Reply With Quote
Old 12-22-2011, 03:16 PM   #3
Originally Posted by EeePee View Post
Two channels only.
HA! I could make it completely mechanical, increased RPM would lock it up. I'll let Microgoat use one in his 3 wheeler.
Old 01-09-2012, 05:06 AM   #4
If its mechanical, from what I read its legal.
articzap is offline   Reply With Quote
sportsman question - Similar Threads
My sportsman take 2 adamargue Axial AX-10 Scorpion 2 07-31-2011 10:19 PM
Sportsman or Mini that is the question... ittybitty South Carolina 15 11-12-2010 02:23 PM
Sportsman! TURTLE Colorado 14 11-12-2009 10:32 PM
