Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > XTM Crawler
Thread: Comp Twin Build
Old 09-21-2007, 01:14 AM   #1
Default Comp Twin Build
Just a mock up shot to get measurements, and sorry the pics are a little blurry. But I think you can get the idea. Not sure yet if I will build a stick or a high clearance linker. Maybe both to see which I like better.
This way I will run 3 drive shafts. The one in the middle will have carrier bearings up high.
426rider is offline   Reply With Quote
Old 09-21-2007, 01:25 AM   #2
TEAM MODERATOR
Reflection's Avatar
Interesting. I'm curious how it'll work.
Reflection is offline   Reply With Quote
Old 09-21-2007, 02:04 AM   #3
Release your anger..
ThinkTank's Avatar
That is very different and unique.
On to the chassis:
Do you think this might be of any use?
ThinkTank is offline   Reply With Quote
Old 09-21-2007, 08:11 PM   #4
You just planning on the tranny on the front axle right? I've seen a TLT built like that on here somewhere. If you are planning the rear axle to have a tranny too, I've seen that on here as well, not sure what type of axle but it was a super axle, not 2.2. Looks like a good start, bulletproof axles is always a good start.
Jamus is offline   Reply With Quote
Old 09-22-2007, 09:02 PM   #5
is it a commenly done thing mounting a tranny to shafty axles like that? ive never seen that before and it looks cool, i wanna see one in action
ctrwannabe is offline   Reply With Quote
Old 09-22-2007, 09:21 PM   #6
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I set up a mad force axle like that- even used the same tranny, ended up ditching it because I couldn't get the mount strong enough. I think it is a great idea for a shafty though.
JohnRobHolmes is offline   Reply With Quote
Old 09-23-2007, 01:04 AM   #7
I hadn't seen it before but I know there is pretty much nothing new under the sun. I am trying to build a pretty strong mount so we will see how it goes. If it's not good enough I will try again. Will get more pics up this week.
Jamus- Just one tranny, hoping to keep the weight low. I have seen the TLT's with the motor mounted to the axle but not the tranny's also.
Old 09-23-2007, 11:45 AM   #8
so you have one tranny and one motor on each axle , then connect the 2 with drive shafts? is there a 3rd tranny on the chassis?
Old 09-23-2007, 11:53 AM   #9
TEAM MODERATOR
Reflection's Avatar
No,one tranny and motor all on the front axle.. They'll be a drive shaft going to the rear axle from the out put of the tranny on the front axle
Old 09-23-2007, 01:53 PM   #10
any pics of this set up?
Old 09-23-2007, 03:33 PM   #11
Took a little bit of digging but here is what I was talking about. Maybe not exactly what you are doing but close. Might get some ideas off it too.
Stick style, TLT build up
Last edited by Jamus; 10-03-2007 at 06:21 PM. Reason: Apparently I forgot the link
Old 09-24-2007, 12:59 AM   #12
Not yet, Still in building process. Wish I had more time to build but hopefully it won't take too long. Gotta have it ready for a comp in mid. October. Lotsa guys in the club have really downplayed shaft driven Super comp rigs. I wanna whoop them with this.
Lets hope it's at least competitive.(along with my driving skills)
Old 09-25-2007, 11:05 PM   #13
Ok, got the tranny/upper link mount done. Still gotta build the middle drive shaft which I will do as soon as I am done posting these pics. Then it will be on to the chassis and links.
Old 09-26-2007, 12:53 AM   #14
You are making some nice progress. Hope it ends up working out.
_BEN_ is offline   Reply With Quote
Old 09-26-2007, 12:58 AM   #15
And here it is with the center d-shaft installed and sitting at 17.5" wb. Seems a little tall but I could shorten the plastic shafts and get it lower. The aluminum shaft will ride down the center of the chassis. Now onto the rear upper link mount and then the chassis. That'll be another day though.
Old 09-27-2007, 12:54 AM   #16
cool progress man youll have to post a vid when your all done
Old 10-01-2007, 01:47 AM   #17
Still haven't done the rear upper link mount yet but did do the chassis and servo mounts. Front end is attached with some temp. links. Ride height and link placement will change some. Still gotta do up the carrier bearings for the center of the d-shaft and some chassis braces.
Old 10-01-2007, 02:22 AM   #18
Very interesting concept. I'd like to see this completed and see how it runs. Nice work so far.
OGmicromonster is offline   Reply With Quote
Old 10-01-2007, 05:59 PM   #19
Bart bender's Avatar
Nice! Another Clod Killer Twin.
Bart bender is offline   Reply With Quote
Old 10-03-2007, 03:07 PM   #20
i like the builders that does that much work to kill the damn clods. i will follw this and see how it turns out
jonass is offline   Reply With Quote
