OK, another fairly productive afternoon...
There was something bugging me about the rear suspension setup. I just did not like the bracket that I made earlier for the upper 4-link mounts. I replaced that with a piece that bolts to holes already in the axle. It has a nice tubular look and by folding the mounting plates over the back side, I was also able to incorporate a tubular rear axle guard as well.
Somone had asked earlier if I was using 3/16" tubing and what I was bending with. Yes, all the tube work is 3/16" brake line and I have been using a simple hand bender that I picked up at the local auto parts store. I would like to make a nice roller style bender at some point though...
The final task I had before breaking things down for paint was to get the body mounted. Originally I had planned a velcro mounting setup to keep the pins hidden but once I added the roof rack, I realized that was not going to be stable enough. What I ended up with is sort of a compromise, but seems to hold the body good and solid and it is pretty easy to take it off.
For the front, I put two screws through the body to act as "pins" that go into the metal mount. I placed the screws in one corner of the lower inlets to hide them a little visually. I used some sharpie to simulate the rest of the inlet to see the effect.
For the rear I needed to mount it in a location that was good and sturdy and as out of the way as possible. I chose to make the mounts up high near the roof rack mounts because the body has almost zero flex at that point. I used some short standoffs on the inside that bolt to an aluminum mounting plate. Then some 4-40 button head screws bolt the body in place there. Once the spare tire is in position, the screws are hidden from plain view.
Well, at this point the FJ is ready to get torn down and painted. This is the last that it will be together for a little while. I guess it is also time to start detailing the body and working on the grill that I want to do for this thing. I am really getting stoked about getting it back together and seeing everything in black. Heck, I am starting to get excited about driving the thing too!
