Szczerba
Thanks to all that helped out. I think I finally found a great setup for me. Several trails with wheel weight but I got it down now. Chassis is very predictable and flexes just enough. Steep uphills, sidehills, you name it's climbing it. Now if I can get the driver to be as good as the truck
Kamikaze Kustoms Zero ST, Medium links, 3 1/8" belly clearance,
12 1/4" wb
CDW OTA Steering, Vanquish Knuckles
Losi .9's up front (some super thin shock oil i found laying around).
70mm links in rear
Tekin Fx-R mounted on one side mounted post with small plate, Fx-R can be unvelcro'd and dig switches rotate up to have access to Nomadio receiver and work on chassis. HH Manly dig switches (electrical tape on dig switches to keep them from rubbing the chassis nuts/bolts), 11.1v lipo, 35t's 12 pinions, big fancy servo
Mayhem 7's and chisels, nomadio react , ok pictures
12 1/4" wb
70mm links in rear
