Ya, like jump all the way to the top of that one climb that gave you so much trouble with your berg:lmao:
Just got my Psycho 'locks
let us know what you think
i sound like JIA now:lol:, Cory your rig is looking sweet
:shock: that is light, hope it doesn't get blown away by a wind gust:lol::ror:
Thanks Carlos.
Took it to work to weigh it today. With the Cobalt puller which is 6.5 ounces (0.5 ounces heavier than the typical 540 can motor), and a 2S 800 mah lipo (which is a ridiculous 1.6 ounces), but still missing the ESC, RX, spur gear and body, I'm at a scant 4 pounds 3.7 ounces.
4 pounds, 3.7 ounces. :shock:
The last version of my AX10 was 4 pounds 14.2 ounces RTR.
Get some lighter delrin lower links and I should be below the 4 1/2 pound mark RTR. The front wheel/tire combo is 10.7 each, the rears are 8.8 each. That's 39 ounces total.
Total weight right now is 67.7 ounces. Subtract the 39 ounces for the wheel/tire and the rest of the truck weighs 28.7 ounces.
We'll be watching...keep in mind everyone, this is a preproduction unit.
EeePee, I'm putting mine on a diet to get under 4 lbs with dig :lol:
whens this chassis susposed to come out and whats the belly clearance, with the panthers?, oh is there any issues yet on trying to mount a body?
If the top hole was straight up, instead of headed inwards, those would be great body mount holes.
And I guess I meant in my case. I know DNA Don has his together and looking great, I'm still working on mine. :ror:
It'd be sweet if he could get the body post holes in the same spot as the stock Axial holes so the body would just transfer over...
cant wait to see a vid to see how it performs
Yeah, I run a spreader that measures 2.35" wide to clear my spur. I'll most likely move the upper hole off the spur for more clearance though.
Looking good EeePee bring it to Oaks Parks so We can see it.
How about one of those 500 mah lipos we were getting talked into at ECC? Did you ever try one? Impressions?
So going back to shaft no dig, whynot run 1.9?:ror:
Looking good, time for some beer?
I cut that hole off as well by the spur;-)
I used the 3mm threaded rod for the Axial links threaded into the spreaders to mount my Axial body mounts, works good yo"thumbsup"
Some people use less throttle than me....and can get away with it on the front:ror:
