Scx 10 link lengths.
calikingcrawler
Crawlifornia
OG SCX10: I'm looking for the length "eye to eye" of the front and rear uppers and lowers. Making my own links, have all I need but the measurements. If anyone can help it would be awesome.
lowers are 115mm ETE
uppers have a 60mm link with off set rodend and the "Y" link connecter then a 6mm spacer between the Y connecter and where the 3-link connects to the axle, not sure what 4 link would be but with the axial truss id use the same leingth or 5mm shorther"thumbsup"
So roughly 4 1/2 inches. I don't remember the front and rear being the same length, but I could be wrong, been drunk to many times since I owned the OG
What four link are you using? That would help a lot."thumbsup"
Well I was thinking about using urs, unless I can find an axial one dirt cheap.
Really I am just worried about the lower link lengths so I can set WB the uppers I can adjust to whatever I use.
The standard SCX10 lowers are 105mm center to center, or just the link length is 91mm. Not sure on the uppers, I use the hand Bros kit in front and my truss in the rear. But the kit came with 60mm links to use with the bent rod ends and three link "Y". Hope that helps some."thumbsup"
It actually does. I just picked up another honcho body so I may go with those links now. I have a honcho now so I can get the lengths from it. But if I use the stock honcho 106mm lowers and ur upper mount what length uppers do I need. I run 106mm uppers on my honcho now with the axial mount.
The r2j mount uses the same links upper and lower "thumbsup"
I think the axial one is suppose to use shorter ones on the uppers
