Dont do anything too crazy with the hex pins just yet.... I think I have the PERMENANT answer. Give me a couple days and I will post up.
Its here. Check this thread:I am holding my breath waiting for this fix...."thumbsup"
Nice!Talk about fast shipping, from UT to the bayou in 2 days."thumbsup"
Thanks man, I hope to put them in tomorrow night and will start putting hours on them Monday. Really looking forward to it.
They came pre-greased with what I believe is the Lucas Red Tacky compound.
While installing my worms I noted that I had decent wear on my spools. After installing the rear first I made sure it turned smoothly by hand by turning the driveshaft...it turned very smoothly. After installing the front and noticing some heavy wear and slight grooves half way down each and every spool tooth I just figured I would run it. When I went to turn the drive shaft by hand it would turn half a turn and then bind up...????
Losikid, yours was tight on the spool because you had a test batch that is not a standard worm.
Who knows on his. Sounds like something wrong with the spool if he can change spools out and run fine.ok, i know that, but why would it be tight on his then. I'm thinking we may have had the same problem since you said the few running the gears i was didn't have that problem.
It should be working for you now. Let me know if you have any issues.Hello M8,
I cannot order from your page. Merchant Dlux does not ship to Turkey
2x mean worms
2x mean pins (std length)
couple cool stickers...
cheers.
Why did you replace the first set, did it effect the car?Thats what 2 sets of my spools have looked like. The first set where originals that I had in with the factory worms. After seeing them look like that I thought maybe they were just bad from the old worms.
Stuck a brand new set in front and rear and 6 packs later I got the same thing again. Strengthen one area and you find the next weak link :ror:
The only spools I have seen are mine and Tydl's. Sounds like yours end up the same as ours. I think its just the worm and the spool finding a happy spot with each other.First wanted to see if it was due to the first set being damaged from original worms. My worms never stripped out like many others, I actually had broken pieces right off of them.
I also had a big comp that weekend and wanted to take the risk factor out of anything blowing up lol.
It didnt feel or sound like anything was wrong at all, only reason I even noticed them was I wanted to see how the worms were doing. Those looked great. :mrgreen:
I figured out the problem on my car. It was not the worm or the spool.
