Installed the Bigron battery mount tonight. Works well with the MaxAmps 430's 8)
Sweet mount. Do the 860's fit there also??
I am also going to make one more change before the Midwest Challenge. I am taking out the FXR's and going to Castle Sidewinder Micros. Not Mambas. Im going to keep a complete second electronics setup handy but I'm pretty sure that these will work just fine.
I have been running the Sidewinder micros since January. I really couldn't be happier with them.
Nice battery mount, so you cant run a 800mah on it? What is the largest pack you can run?
I can't fit any larger than that pack but it is due to the skid plate of the BJv4. If I trimmed it back then I could run the 860 without an issue.
My skid is flipped backwards so I can run an 860 on the mount
BTW, where did you get your sidewinder micros? Best price?
Any difference between the FXR and the CC? Ive got 2 brand new FXR's with 45t motors and I was shocked to see you switch over to CC instead.
I wish I could tell you. Until I get them replaced I won't know. I just like to try all kinds of different options. It helps to be able to support things like the 4PK and 4PL when I can help people with setup and such.
I just also made the switch...Just to see the difference...Was running FXR's.
The FXR's are solid because of the size, there just very throttle jumpy..They are
still way smaller then the Mamba Micros though. But the castle stuff is soooooo
smooth, and I just like Castle. I'm glad to make the switch, plus I would also
break the caps off of the FXR's sometimes, hated that.
I'm very curious about your opinion on the ESC switch.
