JeremyH
As some of you may or may not know, I won the RCC Win It Before You Can Buy It Wraith Giveaway.
My plan is to build this truck and run it in the Crawler Innovations G6 Scale event this coming weekend. It will be cutting it close, but I think I can do it! :ror:
Badger shipped out the kit quickly and I got it on Wednesday evening. I immediately tore into the box!
Specs:
Wraith Kit
Lunsford LCC Lower Links
MIP Driveshafts
Axial Overdrive/Underdrive gears
Losi Xcelorin 17.5T, MMP1C, CCBEC, Futaba 4PL and Rx, Blue Lipo 30C 4000mAh 3S lipos, Futaba BLS152
CAC Slash Beadlocks, R35 Ripsaws, Crawler Innovations two stage foams
Very nice tires!
Extra goodies:
Electronics:
These axles are so cool! They even have bearing caps!
Tranny:
Drivetrain:
Wheels and tires:
I decided to run my CAC Slash Beadlocks.
I had to remove the nub on the hex to get my CAC wheels to work:
These Ripsaw 35s are very nice...a sticky compound and nice size lugs. They look like they will work very well on this truck. The foams that come with them feel just like the stock Sedona foams and are the perfect size for this tire.
Holy stock steering! :shock:
The lunsford links were a bit short, so I used a spacer:
I think I will need to lengthen the fronts a bit more.
Roller!
After I took all of those pictures, I realized that I had installed the front diff in the opposite direction. A bit of a note here.....to be sure that the diffs are installed correctly, notice the Axial symbol on the cover...if it is facing upward, then you have them installed incorrectly.
I also installed a few o-rings on the rods ends of the tie rod...this really helped eliminate a LOT of the slop in the stock steering setup:
A bit more work, and we are ready for the CI G6 Event this weekend!
Specs:
Wraith Kit
MIP Driveshafts
Very nice tires!
Extra goodies:
Electronics:
Tranny:
Drivetrain:
Wheels and tires:
Roller!
