Ok, what is out there? In order for me to buy a servo it has to meet a few strict requirements.
- High torque (111oz or higher)
- Full metal gears (Hitec and other brands put one plastic gear in the box, it sometimes strips that sucks.)
- Horns no servos savers (They have no place on my crawlers I want to turn not load up a spring.)
- Replacement parts (gear sets and spares are nice on those far from home runs as long as they don't out weigh the cost of a new servo.)
- Long lasting (I'm flat out tired of buying servos every month I need servos that last)
- Run time (I don't want a servo sucking down all of my battery juice)
- Standard size (enough said)
- Price (under $100 I'm not made of money)
Stuff I have been using
8 GWS SO6 at $18 each The cheap price and solid unbreakable gear train is a major plus. However, the case and torque is just not up to super class crawling duty and cracks. Also the centering device goes out after a while leaving the servo hunting.
2 Skylon Cen servos $32, seemed good at first, good torque, cheap price, very strong case. After a while one of them lost all of its power and it was weak. I chipped off some of the gear teeth in the other servo i had.
Hitec digital 5545MG or something like that, Free I won it in a giveaway. Longest lasting servo thus far. However, it is currently has issues going full strokes. It just kind of pulses when it turns. I like it though, the torque output is good (165oz) it could always use more. But, I'm guessing with a wheel adaptor change I bet it would be about right. Anyone know how to send in a hitec servo for repair?
I'm looking for a solid servo that can steer my Clod stick crawler around. With this latest comp craze here in the midwest crappy servos just don't cut it. I'm currently running 40 series Moabs with the Thundertech adaptors. However, I plan to go to Thundertech CVD's and Rcguy adaptors sometime later on. I'm using the super rooster to power the setup. Really just looking for the last servo I will ever have to buy.
A few other questions about servo power.
How long do your reciever packs last on a full charge? How many main packs do you run though before you change your RX pack? Do you gain noticeable runtime for the main pack?
Would I see any real power gain if I decided to tap 5 of the cells from the 6cell stick pack used for main power? Verses if I used the Super rooster to power the servos.
