Shocks turned down
Nice build Erik... it would look cool to have two 7980's mounted to one side of the axle, looks like there might be room:mrgreen:
:drool:
Very nice "thumbsup"
You done yet???;-):ror::ror:
Is it the angle the picture is taken at or is that link mount not in the center of the axle? If so will you need to add a spacer to the long side or make a thicker case block to center it up?
I got a weight on the chassis. Seems like its a decent weight. I would eventually like to get into carbon fiber and cut an ounce or two. Can anybody tell me how this weight would compare to an "average" chassis?
krawlfreak said:
Also; I think that's a very good weight for your chassis.
Dammit. I am not going to build one of these right now...
Are you going to mount your electronics on your axles? Would help balance your side to side bias.
Coming together quite nicely Erik! "thumbsup"
I'm itching to see how you are planning your links and shock mounts, you always come up with cool new ideas!
Can't wait to drive it in arizona:twisted:
Looks like I need to send you another set of my spring cups.
Why so tall on the shock mounts? Cleancut parts though."thumbsup"
Is there room within the class specs (re body/chassis length) to use some LCC style upper shock mounts and fix your angle? Running the shocks more upright would give you more steering room too.
