This is from DrugFacts.com. I highlighted the sections important to you in bold.
How Does Marijuana Affect the Brain?
Scientists have learned a great deal about how THC acts in the brain to produce its many effects. When someone smokes marijuana, THC rapidly passes from the lungs into the bloodstream, which carries the chemical to the brain and other organs throughout the body.
THC acts upon specific sites in the brain, called cannabinoid receptors, kicking off a series of cellular reactions that ultimately lead to the "high" that users experience when they smoke marijuana. Some brain areas have many cannabinoid receptors; others have few or none. The highest density of cannabinoid receptors are found in parts of the brain that influence pleasure, memory, thinking, concentrating, sensory and time perception, and coordinated movement.<SUP>1</SUP>
<SUP></SUP>
Not surprisingly, marijuana intoxication can cause distorted perceptions, impaired coordination, difficulty with thinking and problem solving, and problems with learning and memory. Research has shown that, in chronic users, marijuana's adverse impact on learning and memory can last for days or weeks after the acute effects of the drug wear off.<SUP>2</SUP> As a result, someone who smokes marijuana every day may be functioning at a suboptimal intellectual level all of the time.
Research into the effects of long-term cannabis use on the structure of the brain has yielded inconsistent results. It may be that the effects are too subtle for reliable detection by current techniques. A similar challenge arises in studies of the effects of chronic marijuana use on brain function. Brain imaging studies in chronic users tend to show some consistent alterations, but their connection to impaired cognitive functioning is far from clear. This uncertainty may stem from confounding factors such as other drug use, residual drug effects, or withdrawal symptoms in long-term chronic users.
Does this mean that ALL those who smoke weed are "dumb?" Nope. Does it mean that marijuana ABSOLUTELY affects your brain. Yup. Are those affects forever lasting? Unclear. But what IS clear is that you are GROSSLY misinformed & I doubt most pot smokers would want YOU as their ambassador. "thumbsup"
:shock: YOU brought em up dude. Don't be mad because you were wrong maaan. Take a toke & chillax bruh.
Okee dokee smokey. "thumbsup"
