GySgt Hartman
My 2007 BMW went about 11,000 between services, my 2011 looks like its going to go 15,000. I don't get-it, but I assume they know what they are doing...
Ha! I "cleaned" my air filter that same way last night..."thumbsup"My favorite is the dirty air filter routine all the quick lube places pull on you. Years back, I told the guy not to worry and he kept arguing. I took the folder, banged it on the counter a few times, then handed it back to him and said "good as new, no put it back in please".
How much oil does it hold? BMW usually puts a good size oil pan on so it holds a good amount of oil vs engine size. Plus their oil monitoring system is quite good on the BMW.
I think the oil change interval depends mostly on the vehicle and usage.
I was a die-hard 3K/3 month guy for a long time, but I've leaned more towards this philosophy over the past few years. I also believe the old 3K/3 month belief is outdated.
My 1987 BMW 325 holds a little over 4.5 quarts on a 2.7L straight six. I use as I posted earlier the Rotella T 15-40, I've read it has a high zinc content and is good for the older engines. Anything lighter and the engine seems to drink it. Maybe it just needs a rebuild, some day anyway.
Oh and the monitoring system only involves a level sensor down on the pan and the PSI switch on the block.
