coreyperez
Fellow Enthusiasts,
I know I'm going to ask the same questions everybody always asks, I'll apologize up front.
Here is my story: I'm Military and getting ready to leave my family for at least a year and head to Korea.
I did a bunch of research earlier (actually late last year) and got a XR10 for Christmas, knowing that I was
going to have time to get all this together. Unfortunately life catches up and now I'm on the short list for
getting out of here. I'm trying to get as much of this truck (components) together before I leave so I can
get it all packed up before the movers take my stuff.
In my research I've opted to get the following items:
XR10, 4PKS-R, Vanquish: Axle motor plate, Transmission case, Stage 1 kit, SLWv4 wheels (.700 wide)
with a set of 350 and 475 hubs. to ensure that I'd be good to go. I've also got tires w/foams. Included
in my build list is a semi-decent set of tools to help assemble this when I get over there
(to include a soldering iron).
A little about myself: I suffer from "I have to have the very best $#!T money can buy". That in mind,
I actually don't plan to do any comps, I just want to have a solid rig. Having spent WELL over 1000$
I'm trying to be mindful of the remaining purchases.
Now the actual questions. I've spent way more time than I really should have spent away from my 3 boys
and the wife trying to decide on the remaining components. I've gotten flattened with the Motor and all
the crazy options, spur gear / final gear sets, ESC, power supply, servo & battery. Ultimately it seems like
any one thing will change the rest of the components so I'm just sitting here spinning my wheels trying to
figure out where to start and what to get.
For the ESC I've basically decided on a Mamba Micro Pro, UNLESS… the Holmes BR-XL (with included BEC)
will eliminate the need for a CC BEC. (Before I go too far, although they (Castle) says "Brushless" I hear
of everybody using them for Brushed motors. Is this ok??) For programming I believe that either the
Holmes or CC will use the CC Castle link USB programmer (010-0005-00) or do I need the CC Castle Link
Quick Connect (010-0079-00)? Back to the BEC, it appears that I need just one BEC
(regardless of one or two battery packs) correct?
With motors I'm THINKING of HH Torque Master 540 w/45 turns. Basically limited to what is available at
this point (and at a reasonable price). My take away was basically getting a HH hand wound was the way
to go. Unfortunately I got to Holmes site and I got really confused with all the darn options on the motor…
Gearing. I purchased the "upgraded" gears for the transmissions but still need to get the pinion and
apparently some other ?? Final gear set??. Any recommendations for backyard bashing, etc? (pinion count)
Battery.
I'm 100% new to Lipo. I've never used it nor am I setup for it. That being said, evidently I'm going
to be getting some. Either 2s or 3s, any good recommendations with the electronic package and
gearing/motor config? On shipping them. It sounds like these things are little bombs,
I've heard about balancing them, cut-off's, you can imagine. It's all new to me. Typically I'd just use a 12v
(car battery) charger, but being overseas I'm just going to try and find a wall charger. I'll probably be living
on base, so US power should be available. What is a nice charger, one that is programmable to do different
cells/packs, etc? With these packs, are they safe to ship, etc? What do I need to do to ship them/preferred
method of shipping them? I'd probably rather skimp on the motors and get a nice charger/balancer and buy
better motors at a later date.
Servo: Savox? The way to go these days? Do I need a fancy-pants servo case/shield? What servo, servo
arms/horn gets the recommendation these days? Once again, do I need a BEC if using the Holmes ESC?
Thanks! I know I've asked so many darn questions that get asked (I know because I've researched and researched
these options/questions) but typically come up with even more questions and the "answers" are all from 2010, etc.
I'd just like to minimize spending money on outdated things because an old link. Well that being said, it's almost 10p,
the wife is in Anchorage for her Annual Tour, one of the boys fell asleep on the couch and the other two need to be
put in bed. Thanks for listening to all these questions and taking the time to answer what you can.
Corey
Battery.
Corey
