hozer
I'd like your suggestions and example photos on running a 4 parallel link setup wih a panhard / track bar. I did a search and didn't find anything.
Im collecting parts for my New Bright JKU scaler. I plan to uses SCX10 axles, a GCM CrossCanyon Chassis, and a rc4wd AX2 two speed transmission mounted up front. I want the ride hight ultra low, but I still want to be able to have compression. With the motor forward of the towers I will likely hit the pumpkin. With the motor behind the towers and toward the center of the chassis, I will hit the links on either a typical 3 link or 4 link setup. If I go parallel with a panhard, the links can clear the low slung motor/trans and the pumpkin can rise up under compression. It is also more true to scale.
I also plan to run front sway bars as this will be a trail runner. I'm thinking I could mount the shock and lower links in their normal spots on the axle. The upper link and swaybar link could attach to a custom double shear mount that would be screwed on to the axle on top where the 2 holes are (where you'd normaly have the spring pad on a 1:1). The double shear would have the brackets pointing up like a goal post. The front side of the bracket could be boxed in so that I have a mounting point for the panhard.
Any suggestions, problems, or examples? Thanks!
