Harley's LS Hero Rock Bouncer
Those rtr tires should be good for some spinnin footage.
You are going to need to find scale trees to put beside whatever you are climbing for some scale realism.... SNAP
Nice to see you turning to the dark side Josh.:lmao:
KOH, SRRS, Redneck offroad...it's all good. It's hard not to appreciate a southern buggy. Nice work guys. Can't wait to see it pulled together.8)
Every side of this hobby is the dark side!
Appreciating them for what they are is the key, you just can't try to compare them to the other styles of Off-road rigs.
Really excited for this one.
Down travel is key on the front Josh. These real buggies run a whopping 4-5inches of up travel on the front with about a 2 foot droop. Long shocks, small springs, and really thick shock oil is what will make this thing work. Most of the magic happens in the rear with these. They run stiff springs and a good bit of pre-load so when they have to "Back up and bump it" the rear end will jump up ledges and things.
Observe this video of me driving my green goblin. Hardly any up travel in the front and kicking ASS!
<iframe width="560" height="315" src="//www.youtube.com/embed/_WRcFueWhmE" frameborder="0" allowfullscreen></iframe>
As far as steering, you don't need no stinkin steering. Just aim it and hammer down :twisted:
You know you want a big brushless motor in there Harley.
The amount of power out of the brushless motors is great but at the same time I'm not sure how realistic it is to backflip the truck from a standstill. I think a good brushed system will output more realistic driving experiences.
I'll see when we get to that point if that theory is correct or not. I've got brushless systems at the shop, that's definitely not the problem.
Ah i see! Thats a good way to look at it. I've had to resourt to high punch contorl to stop shreading spurs.
I like where you are going with that. If you want really scale you should half foams, these guy run practically no air in the 1:1's :lmao:
Unless you are TC, whos excuse for not airing down is "Sum bitch wont bounce, just cut tires"
I'll probably run the stock Axial foams which are SUPER soft. With the stiff tires + a 10lb rig + very little foam support that should equal a tire that will squat decently when it hits a rock but stands up when spinning.
All theory at this point...
