Hey schnitzel, it does look like erins turns sharper. I checked out harleys thread on his conversion, and at one point he said he had to bend some aluminum parts to align things like shocks, which I seem to remember allowed him to change his steering slightly. Maybe that would help the front of yours (not that you need it with 4ws).
The BMRC kit also needs the bell cranks pushed forward about a 1/2" to get correct geometry. Theres a pic in the wrexo thread of that as well.
Loving the second picture. Looks mean. Have fun testing tomorrow. I will just stay here tied to the truck with a 3 foot rope...but you go and have a good time.![]()
I would limit the rear just a bit. Can you move the drag link to the closest hole, or change to a servo horn with a super short throw? Then do what Erin said and it will get around all the turns just fine. you may not even need the rear steer with throttle steering in the tight turns.
Is the knuckle hitting on both sides equally? Im pretty sure my exo with mips has more throw then that. Ill check tonite after I get it back together.
I like the rear having just a little steer, not to much. Be more controllable at speed.
I agree with limiting the steer. I had fun with the 4ws in my driveway but it's way more than I'll need. I'm going minimal. It's a simple setting on the controller. Once I figure out what works it's set it and forget it!
I know I'll need SOME rear assist after watching Duncan's video again. Look at the 3 point turns and how much he flipped over. He wouldn't have flipped as much if better steering allowed him to nail the approaches. As fast as he was, he would be untouchable without the 3 point turns and rollovers. That's what I'm going for!
Ur gonna love the cvds they've held up to what I've thrown at them...I'm running pro4 on 3s
That's the prob!!! steering sucks!!! Personally I don't know if I would run rear steer full time. Its going to suck when your going fast and just try to correct when you get a little out of shape and that rear try's to steer. Its going to try to make you flip. As you've seen I've gone back to a straight axle and am going to try some different set ups on suspension. I'm going to still work on the IFS steering parts so I hope I can get it to work right. Most of the people don't race so the IFS works for them(at least on a tight track).....I'm really going to watch your rear steer :mrgreen:.... Not that I'm going to do it though.
What cvds are you running?? I haven't seen any cvd other than MIP's that hold up to a locked front diff, or are you open?
I was really impressed by how your beast soaked up every bump and looked so "real" in the handling on the track. Mine looked silly bouncing around by comparison. I'm watching your thread too to see if you can get a solid axle as dialed in as your IFS. I'm just glad I won this BMRC kit because I'm no fabricator and I'm trying to do the best I can with off the shelf parts!
I've got the same cvd's as scottanthony. Steel, dogbone at the diff, and $20 on eBay. I'm hoping they hold up. They're definitely beefier than stock Exo but way lighter than MIPs. I'm a pretty conservative driver so it seems like a good setup for me.
I'm "open" with plumber's putty in the diff. That should be plenty of lockedness unless they really fawk with the boulders.
Don't get any ideas, Jerry.
I know it won't work as good as the IFS, but I'm going to try the trade off for the turns. Open will be a big difference on turning... I know Boltz has broke a few. He was looking at going to mips I think. Here was looking my rig over and asking questions.
