Rowdys there's no "I" in team Bully 2
ROWDY RACING
When I saw Sniper with these at Nats I was intrigued, so when I saw RC4WD was looking for some drivers applying was a no brainer and I am grateful to have been choosen, thanks John. "thumbsup"
The axles showed up today and wow my first impressions of these are excellent. It's really hard to believe you can get axles this nice out of the box stock for the price they charge, bravo RC4WD!
The fit, finish, and tolerances are all nice, clean and not sloppy. There is also a lot of adjustability built into these from adjustable upper link mounts, to adjustable shock and link mounts that can be mounted to the axles in multiple locations.
I will be taking these apart to grease and Loctite before replacing my XR axles with them. Nothing against XR axles loved them and they did me no wrong for years. I am however excited to move on and support a company that supports comp crawling, thank you RC4WD. "thumbsup"
Fresh out the box pic with RC4WD steering linkage added to front axle. Weights as pictured.
Front: 12.3 oz or 348 grams
Rear: 9.4 oz or 268 grams
Couldn't have said any better. I have been running mine and love them, have you noticed they have hole for knuckle weights already. 8)
You'll love them."thumbsup" Welcome to the Team.
Thanks a lot Ricky, yeah I noticed the holes, these things have handy drilled and tapped holes everywhere, very convenient. "thumbsup"
The "i" is hidden in the "A" hole.
My thoughts exactly! "thumbsup" Looking good so far. Are you gonna run with Double Agent?
Congratulations on making the team Chris. Are you going to modify the axles or just run them as they are? Can't be long till someone starts putting delrin tubes on them.
Thanks Josh!
Going to start off stock and let my mind and aftermarket morph them over time. I know you have always loved bully's, do you have these yet?
Nice I can wait to see these in action. Should be a pretty tough axle right out of the box if they're anything like the bully 1's. You gonna drop these in the same chassis you currently run or go with something different?
They will drop right into my current setup.
Don't have them yet. I am still having a good time with my old axles. When they are not reliable any more I'll be looking to upgrade.
