tapped-out
Looking good man!8) Looks like your missing something swaybarish in the rear;-)
Maybe someday...... "thumbsup"
I guess, I really don't understand the benefits of running one...Just out of curiosity. What holds you back from running the sway bar?
It should help with the rear unloading on steep sidehills keeping it more planted, at least I think that's what it will do. I'll be using one as soon as it gets here so I'll let you know exactly what it does."thumbsup"
Rig looks good, as do ur tire's(to me).. a softer set of foams and the warn carcus's should hook just as good..![]()
Looks good man! Excited to run with you again soon.
Thanks..Lol.. tires and foams I have actually do work well together 5.25 crawler innovations CC foams soft up front(comp cut) medium in rear & some old red dot Rovers"thumbsup"
I run the same setup in my BC's, minus the CC front.. they weren't out at the time.. tho, I have ran enough packs thru them to get the tires dam near bald and the inner foam is more like pretzel dough in shape and super beat down and soft.
"medium in rear & some old red dot rovers" ???? What/where do/are the red dot rovers?
I do stalled my brackets the easy way. I just shoved them in between the cross braces and the main plates and added a washer to take up the gap in the most forward of the rear braces. Lol
If I did that, it would bug me knowing it Wasn't a perfect fit.
