You are still building after all this time, so I really applaud you for that.
Again, please don't take this the wrong way, but as I was reading the ENTIRE thread, I basically have the same sentiments as the person I qouted above.
I was bit by the RC bug when I was just in middle school, so while we all know you are just 15 or 16, think of how much less access to resources I had when I was just 13?!
I would like to ask you an honest question: What is your goal with this truck? Do you enjoy the building/fabricating or do you enjoy the driving more?
If you enjoy the fabrication aspect of this hobby, then that is where there is really a major disconnect between your ideas and your ability to turn your ideas into reality. You will be short on access to the proper tools and materials to make what you envision in your head. If you look here on the forums, there are a bunch of us here that still can't make anything properly even with access to a full machine shop :lmao:
The first observation I have, and my main complaint about the younger folks I have to train at work, is the general "meh, that looks like it will be good enough" mentality. If that really is the best that you can do with what you have, then I guess that's fine. But if it's just simply access to tools and know-how, I'm sure that you can find a machine shop or sheet metal place that can help with your ideas in exchange for some grunt work like sweeping all the chips off the floor (run away if they want any type of "favors" if you know what I mean).
The second observation I have is that you are trying to re-invent the wheel. I fully appreciate that you may want to make something that is truly your own, but trust me, everything that you want to make, someone has already made it. There is a lot more to suspension and chassis design--even in RC.
My suggestion? Modify or adapt an existing design. Here's an example of a well thought out, mainstream design that you can adapt to what you already have:
Hardcore Slash G10 Upgrade Kit
Incorporate some of your ideas into this design.
That search took me about 5 minutes. That's one advantage that you have that I didn't 23 years ago--the internet. If you were, ahem, meticulous about your work methods, you could estimate the mounting locations of a lot of those components with at least 80% accuracy just from the photos alone. Your accuracy would go up even more if you went and measured some of the stock parts being used on that model and used that to scale off the rest of the chassis.
Well, I'm off my high-horse, so I'll keep my eye on this build to see where you are. Good luck and I would like to see where you end up with this truck.
