Has it been posted any where when axial when be posted all the info?
Brandon?
Would you please proof read your posts before hitting submit? We would all appreciate it.
Why are the trailing arms so narrow on the axle? I get they used the wraith axle. But wouldn't the yeti and wraith be better handling and more scale if the the trailing arms/links were positioned closer to the tires?
I guess I'm adding to the complaint list even tho I intend it to be more of a observation... Why are the trailing arms so narrow on the axle? I get they used the wraith axle. But wouldn't the yeti and wraith be better handling and more scale if the the trailing arms/links were positioned closer to the tires? Other then that tho this rig looks to be a great platform. Thanks Axial!! Hopefully the traxxas relations will cease now.
Because one axle is used front and rear on a Wraith and if you widened the link mounts you wouldn't get any steering angle.
Yeah, lol I should've thought a little harder before speaking. Non the less would the rear of the yeti in some applications benefit from a wider trailing arm position? Not to mention give the shocks better stability/leverage... Perhaps it would work against rock crawling tho. Would be nice if aftermarket axles could accommodate a more outboard position for those that want it. Especially if anyone wants to make a sc truck.
Sent from my subconscious to your screen.
If the trailing arm is mounted clutter to the wheel, then that would effectively decrease the leverage on the shock & spring. It is very similar to a shock mounted on an IRS or IFS setup in that the closer the shock is mounted to the wheel the less leverage the wheel and suspension arm have to compress it. Mounting the shock further away from the wheel does the opposite and increases the effective leverage.
I hope this makes sense.
It does and that is the principle behind mounting the shock further up the trailing arm. It achieves more travel with less needed shock length as well as multiplies forces during compression and rebound. But in the context on a trailing arm set up not A-arms where the pivot is different, would a more outboard trailing arm position on the axle provide better leverage regarding stability?
By the looks of the two body posts up front, this thing is going to be a pain to get in![]()
I prefer to run the rear links on my AX-10 axle housings on the outside of the mounts. You lose the double shear, but it doesn't really seem to bother anything. I've never done it on my AR housing trucks but I don't see why you couldn't.
Imo this truck needs s SC body.
IFS on a scale crawler truck? It's like a Tamiya's XC but widder and bigger wheels.
99% of the forum users try to gain more axle flex, not more camber.
https://www.youtube.com/watch?v=URWLnItt5p0
IFS on a scale ULTRA4 truck, not a scale crawler specifically.
And 99% of the users on this forum in 2004 were looking for more flex, but 10 years later we have realized where certain characteristics are beneficial. This will not be winning crawling comps, but that's not it's purpose.
And just one of my favorite examples of an IFS Ultra4 Truck
Scale Ultra4?
1/1 truck rides 55" tall tires and 22" rims?
