TheAxialNut
Can't wait to see this beast on the rocks this next season.... Nice work Josh.
Looks good to me... will you have to retemper the steel? Or mill and run?
So the short side Wraith is too short, so cutting down another long side wraith shaft would be best correct?
Or maybe XR shafts, I will check it out on mine soon.
The short side was roughly .100 to short. I just added a little material to the end when I welded up the ends.
I didn't try xr shafts. VP cvd's may be a good option if the shafts are 5mm then all you would have to do is trim them down and put the flats back on.
I didn't try xr shafts, let us know how it goes."thumbsup"
ThanksAwesome work Josh
we all appreciate you sorting this out for us. Write the formula!
Thanks
"thumbsup"
Formula?
Formula: a set form of words, as for stating or declaring something definitely or authoritatively, for indicating procedure to be followed,
Pretty sure he explained how he did it, I understand.
so he's done? it's all figured out? he isn't going to try out the vanquish axles? That's what I thought.
