axial 4x4 crawler
Woah you beat the living hell out of this rig lol Jk Great build, looking forward to some more updates!
Yeah running the gears on the drive side will be your best bet, just curious, what kind of shims are you going to use? I've thought about shimming the gears in my wraith so it doesn't screw up the diffs with all of the power it has.
Might as well throw the last spare axial locker in there to last the weekend.....
damn man carnage everywhere. not sure you even like the wraith that much. I think I like your style. give it hell my friend. Enjoy "thumbsup"
I really like your own approach to making this rig a style of your own but still be U4 themed.
I can't find any other pistons specifically for these shocks. If some other pistons work, I would love to know which ones.
Stripped a double clamp servo horn, blew the front ring gear and wore a hole through the front diff housing at lunch. :lmao::lmao::lmao:
HD gear set ordered, servo horn picked up and not worrying about the housing for now. The servo horn was loose on the servo splines and clamped tight to the center bolt. I will drill out the center hole to not contact the bolt before the splines are clamped properly.
Maybe just put some epoxy or shoe goo on the housing to keep dirt out
My old servo horn was a china GH double clamp copy. The metal was noticeably soft, and with the clamp bolts loose the horn would slide on and off the splines easily. The new part in the gold axial horn. With the clamp screws completely out I couldn't even press it on to the splines. Much better. I'm confident this one will last a while.
